What is hydrogen loading treatment?
Why is it necessary for the fiber optic to first “absorb” hydrogen before grating inscription?
The process of letting optical fibers “absorb” some hydrogen before grating inscription is known as Hydrogen Loading Treatment in optical engineering. It is a classic and critical universal technological process for manufacturing high-quality Fiber Bragg Gratings (FBGs).
Here is a detailed explanation of the physical concept, chemical mechanism, and engineering principles of this process:
1. What is Hydrogen Loading Treatment?
Hydrogen loading treatment involves placing bare or coated silica fibers in a high-purity hydrogen gas (\\text{H}_2) chamber under specific consultative high pressure (typically 10\\ \text{MPa} to 20\\ \text{MPa}) and appropriate temperatures (e.g., room temperature to 80^\circ\text{C}). Due to the extremely small physical size of hydrogen molecules (\\text{H}_2), they gradually penetrate and diffuse into the silica (\\text{SiO}_2) matrix and the germanium-doped (\\text{Ge}) core of the optical fiber until saturation dissolution is achieved.
2. Why Perform Hydrogen Loading? (Core Physical/Chemical Mechanism)
Standard single-mode fibers (like commonly used germanium-doped fibers) have relatively low photosensitivity when untreated. This means that even when exposed to strong ultraviolet (UV) laser irradiation, the refractive index change in the fiber core is very limited.
Hydrogen loading treatment can significantly enhance the photosensitivity of the optical fiber. The mechanism is as follows:
  • Formation of Photochemical Reactions: When hydrogen-loaded fiber is irradiated by a UV laser, the dissolved hydrogen molecules undergo photochemical reactions with germanium-oxygen bonds (\\text{Ge-O-Si} or \\text{Ge-O-Ge}) within the silica network.
  • Generation of Defects and Groups: This reaction generates a large number of hydroxyl groups (e.g., \\text{Ge-OH} and \\text{Si-OH}) and simultaneously creates a high concentration of color center defects (e.g., \\text{GeE'} active centers).
  • Significant Refractive Index Change: These newly formed defects and groups cause strong absorption in the glass matrix within the ultraviolet spectrum. According to the Kramers-Kronig relation, this leads to a significant increase in refractive index in the visible and infrared bands. The refractive index modulation depth (\\Delta n) of hydrogen-loaded fiber can be one to two orders of magnitude higher than that of untreated fiber, easily reaching the 10^{-3} level.
In summary, hydrogen loading is performed to facilitate easier and faster modulation of deeper periodic refractive index changes within the fiber core during UV inscription, thereby obtaining fiber gratings with high reflectivity and high-quality spectral lines.
3. Subsequent Key Engineering Step: Annealing Treatment
During hydrogen loading, some of the hydrogen gas absorbed into the fiber exists in a free state. After grating inscription, these unreacted free hydrogen molecules gradually diffuse outwards and escape the fiber over time. The loss of free hydrogen can cause a slight drift in the effective refractive index of the fiber, leading to instability in the grating’s center wavelength (\\lambda_B).
Therefore, after inscription, the fiber Bragg grating must undergo high-temperature annealing stabilization treatment (typically at 100^\circ\text{C} to 150^\circ\text{C} for tens of hours). This step effectively drives out residual free hydrogen and anneals the metastable structures formed by photochemical reactions to a thermodynamically stable state, ensuring the long-term wavelength stability of the grating in subsequent sensor applications.
4. Related OFSCN® (Dacheng Yongsheng) Products
In Beijing Dacheng Yongsheng Technology Co., Ltd.'s official core product line, many bare Fiber Bragg Gratings and grating strings strictly employ the preceding high-pressure hydrogen loading and subsequent precision annealing processes during inscription to ensure that the grating’s reflectivity, bandwidth, and wavelength stability meet the high standards of industrial-grade sensors:
(1) OFSCN® Polyacrylate Fiber Bragg Gratings / FBG Strings (Bare) | Official Link
This product uses standard single-mode fiber. Before UV mask illumination and inscription, it undergoes hydrogen loading and coating removal. After inscription and annealing stabilization, it is recoated with Polyacrylate for protection.
(2) OFSCN® Polyimide Fiber Bragg Gratings / FBG Strings (Bare) | Official Link
This product is designed for medium-high temperature or extreme environments. It also undergoes high-pressure hydrogen loading before inscription, followed by precision annealing after inscription. It is then recoated with Polyimide material, allowing for an operating temperature range of -200^\circ\text{C} to 300^\circ\text{C}.
