What does "impact resistance" mean?
If heavy objects fall on the jumper wire on a construction site, can it guarantee uninterrupted signals?
For this issue, we need to provide a scientifically rigorous answer from three perspectives: the physical failure mechanisms of optical fibers, the structural differences between various patch cords, and the engineering quantification of impact energy.
I. Physical Mechanisms: The Impact of Heavy Object Strikes on Fiber Optic Signals
When a heavy object strikes a fiber optic patch cord, it can have two distinct physical effects on the internal silica glass fiber (SiO_2):
  1. Mechanical Fracture (Permanent Failure):
    Standard single-mode optical fibers have a cladding diameter typically of only 125\ \mu\text{m} and exhibit extreme brittleness. Under intense localized shear stress and radial compressive stress, if the stress exceeds the material’s limit for compression or fracture strength, the fiber will instantly undergo physical fracture (fiber break), leading to a complete and permanent interruption of the optical signal path.
  2. Bending Loss (Transient Attenuation):
    Even if the heavy object does not break the fiber, the instantaneous lateral compression caused by the impact can induce sharp localized microbends and macrobends within the fiber. According to optical waveguide physics, bending causes light that is normally transmitted via total internal reflection within the core to leak into the cladding. This results in a transient drop in optical power, manifesting as momentary signal attenuation in the transmission system.
II. Performance Comparison: Standard Patch Cords vs. High-Strength Armored Patch Cords
1. Standard Fiber Optic Patch Cords
If standard non-armored fiber optic patch cords are used, such as:
These patch cords consist only of a PVC jacket, aramid yarn (Kevlar), and tight-buffered fiber. Their structural design focuses on axial tensile strength and possesses virtually no lateral compressive or impact resistance. On construction sites, even lighter manual tools (like wrenches, screwdrivers) or falling debris can cause instant fiber breakage, offering absolutely no guarantee of signal continuity.
2. Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) High-Strength Metal Armored Patch Cords
To ensure communication safety in harsh environments like construction sites and heavy industrial settings, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers specialized armored patch cords utilizing seamless stainless steel tubes and stranded steel wire structures. These patch cords can mitigate and dissipate lateral impact forces through their metal protective layers:
  • OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord
    • Armored Structure: Features a 0.6\text{ mm} thick-walled seamless stainless steel tube embedded within a PVC jacket.
    • Performance Specifications: Tensile strength \u003e 150\text{ N}, compressive strength \u003e 240\text{ MPa}.
    • Protection Principle: The high-strength seamless steel tube acts as a rigid radial “protective shield,” capable of withstanding and dispersing most localized compressive stresses to the sides upon impact. This prevents plastic deformation or excessive microbending of the internal fiber.
  • OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord
    • Armored Structure: Composed of an outer PE jacket, a 0.45\text{ mm} stranded stainless steel wire rope structure, an inner 0.9\text{ mm} seamless stainless steel tube, and the optical fiber.
    • Performance Specifications: Tensile strength \u003e 1200\text{ N}, compressive strength \u003e 200\text{ MPa}.
    • Protection Principle: This product incorporates a stranded stainless steel wire rope structure outside the seamless steel tube. When subjected to a strong impact from a heavy object, the stranded steel rope absorbs a significant portion of the dynamic impact energy through slight mechanical deformation, providing excellent elastic buffering, damping, and a dual physical barrier against impact.
  • OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord
    • Armored Structure: A fully metallic structure, including a 0.6\text{ mm} galvanized steel wire rope structure and a 1.0\text{ mm} inner seamless stainless steel tube.
    • Performance Specifications: Tensile strength \u003e 1500\text{ N}, compressive strength \u003e 150\text{ MPa}.
III. Practical Engineering: Can
