How are two optical fibers “aligned” inside a quick connector?
The core task inside a fiber optic quick connector (commonly referred to as a “cold splice” in engineering fieldwork) is to achieve ultra-high precision coaxial alignment of two optical fiber cores without the need for fusion splicer heating.
For common single-mode optical fibers, the core diameter used for actual optical signal transmission is only 8.2\ \mu\text{m} \sim 9.2\ \mu\text{m}, while the outer cladding diameter is 125\ \mu\text{m}. To achieve low-loss connections at the micron level quickly in the field, the quick connector relies on the following four key physical and mechanical mechanisms:
1. Pre-stubbed Fiber Design
Quick connectors do not allow the field-inserted fiber to pass through the entire ferrule. A very short fiber segment (the pre-stubbed fiber) is pre-installed inside its internal structure:
- Front End (Outer): The front end of the pre-stubbed fiber has its end face polished on a high-precision grinding machine before leaving the factory and is secured within the ceramic ferrule (corresponding to the physical interface end face of SC, FC, or LC).
- Back End (Inner): The back end of the pre-stubbed fiber extends into a positioning groove inside the connector and is cut flat by a high-precision cutting blade at the factory.
- Physical Connection Point: The fiber you strip and cut in the field is actually connected “end-to-end” to the back end of this pre-stubbed fiber inside the connector.
2. High-Precision V-Groove Alignment
To ensure perfect coaxial alignment of the field fiber core with the pre-stubbed fiber core, the core positioning component inside the connector is a precisely manufactured V-groove (typically made of ceramic, quartz, or high-hardness polymer liquid crystal material):
- Two fibers are pushed from opposite sides of the V-groove towards the center.
- The physical geometry of the V-groove forces the two fibers, both with an outer diameter of 125\ \mu\text{m}, to be physically confined along the same central axis. This achieves micron-level high-precision alignment of the two fiber cores in the radial direction (X and Y axes).
3. Index Matching Gel Eliminates Fresnel Reflection
At a microscopic level, even the fiber end faces cut with a precision cleaver in the field cannot achieve absolute molecular-level smoothness. When two fibers are joined, an unavoidable microscopic air gap exists between them:
- According to the principle of Fresnel Reflection, when light travels from glass (refractive index n_1 \approx 1.46) into air (refractive index n_2 \approx 1.0) and then back into glass, significant reflection occurs, leading to degraded return loss and increased insertion loss.
- The V-groove connection point of the quick connector is pre-filled with a small amount of index matching gel at the factory. This silicone oil-based polymer liquid has a refractive index similar to that of silica glass (approximately n \approx 1.46).
- The matching gel fills the microscopic gaps between the end faces, allowing the optical signal to transition without sensing a change in medium, thereby eliminating the reflective interface and enabling smooth optical signal transition.
4. Mechanical Clamping & Fiber Bow
To ensure that the two fibers do not disengage due to temperature fluctuations or external vibrations during long-term use:
- Elastic Bow Pressure: During field installation, after the operator inserts the fiber into the V-groove and it contacts the pre-stubbed fiber, they need to push it slightly further forward. At this point, the field fiber forms a slight bend (called Fiber Bow) in a specific housing inside the connector. The elastic force generated by this physical bend continuously presses the field fiber end face against the pre-stubbed fiber, ensuring uninterrupted physical contact.
- Mechanical Locking: While maintaining this pushing force, press down the clamping cover or latch at the top of the connector. The wedge-shaped block inside will compress the V-groove, firmly clamping the bare fiber and coating of the field fiber through friction, preventing any axial retraction.
OFSCN® (Dacheng Yongsheng) Technical Description and High Reliability Comparison
This type of mechanical splice cold connector, due to its ease of manual operation and lack of need for a fusion splicer, is often used for rapid cabling in FTTH (Fiber to the Home) and other civil or local area network applications. However, in industrial control and extreme environment sensing (such as oil wells, high temperature and pressure, strong vibration), mechanical splice cold connectors have certain limitations:
- Limited Environmental Tolerance: The index matching gel can age, overflow, or degrade in extreme high temperatures (e.g., above 80^\circ\text{C}) or low temperatures; the mechanical clamping force may creep with temperature changes.
- Transient Loss Risk: Under strong vibration, the end faces may momentarily separate at the micron level, causing transient signal interruptions.
Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) focuses on high-reliability, harsh-environment optical transmission and sensing systems. Our core products adopt more robust industrial-grade standards:
- Factory-Manufactured High-Precision Cured Grinding: Our OFSCN® 300℃ High-Temperature Fiber Optic Patch Cords, among other products, undergo high-purity silica ferrule polishing using high-temperature curing adhesive and high-precision grinding discs within a controlled factory environment. They do not use index matching gel and provide excellent long-term stability in harsh temperature environments ( -270^\circ\text{C} \sim 300^\circ\text{C} ).
- Field High-Strength Fusion Splicing: For products such as our OFSCN® Triple-Layer Stainless Steel Seamless Steel Tube Fiber Optic Cable used in harsh conditions like oilfield logging or bridge monitoring, we strongly recommend using high-precision fiber fusion splicers for thermal fusion splicing in the field. Thermal fusion splicing melts two glass fibers into one through electric arc discharge, completely eliminating reflective interfaces and the risk of mechanical displacement, thus providing the most stable connection quality long-term, with typical insertion loss usually less than 0.02\text{dB} .
