What is "MRI compatibility"?
Why must MRI rooms use non-metallic enclosures? Does OFSCN® offer ceramic models?
In a Magnetic Resonance Imaging (MRI) environment, the materials used for sensors and cables are subject to extremely stringent physical and electromagnetic safety restrictions. This document explains why non-metallic encapsulation is mandatory from the perspective of optical and electromagnetic physics, and introduces OFSCN®'s corresponding ceramic-encapsulated products.
I. Why is Non-Metallic Encapsulation Required in MRI Rooms?
Magnetic Resonance Imaging (MRI) systems operate with a strong static main magnetic field (typically 1.5 T, 3.0 T, or even higher), rapidly switching gradient magnetic fields, and high-power radio frequency (RF) alternating pulses. In such a complex and intense field environment, metallic materials (even non-ferromagnetic metals) pose three critical physical risks:
  1. Projectile Effect / Mechanical Attraction
    • Ferromagnetic metals experience immense mechanical displacement forces and torques in strong spatial magnetic field gradients. If unrestrained, they can be propelled at high speeds towards the center of the magnet’s bore, creating a severe physical safety hazard.
    • Even non-ferromagnetic metallic conductors can experience minor Lorentz forces during rapid movement or when exposed to switching gradient fields.
  2. RF Resonance Absorption and Eddy Current Heating (RF Heating & Eddy Currents)
    • MRI systems emit alternating high-frequency RF pulses at specific frequencies during imaging sequences. Metallic conductors can induce high-frequency eddy currents, or due to geometric resonance, act as antennas (Antenna Effect) to focus electromagnetic energy.
    • These eddy currents and resonant currents can cause local temperatures to rise by tens of degrees Celsius in extremely short periods, posing a direct threat to the safety of the subject or patient and leading to measurement distortion of the sensor itself.
  3. Local Magnetic Field Distortion and Imaging Artifacts (Susceptibility Artifacts)
    • MRI imaging demands extremely high spatial main magnetic field homogeneity (typically in the ppm range). The magnetic susceptibility of metallic materials differs significantly from that of human tissues and air.
    • The presence of metallic conductors causes severe local magnetic field distortions, resulting in widespread image distortion, signal loss, or geometric artifacts.
Quartz optical fiber, composed of high-purity silicon dioxide (SiO₂), is inherently dielectric, insulating, and non-magnetic, providing natural advantages for electromagnetic interference immunity (EMI-immune) and MRI compatibility. However, conventional industrial-grade Fiber Bragg Grating (FBG) sensors are often armored with seamless steel tubes or metal alloy casings, making them unsuitable for MRI environments. Therefore, stripping off the metal sheath and using all-dielectric non-metallic materials (such as alumina ceramic or engineering polymers) for encapsulation is a necessary engineering measure to achieve “MR Safe” status.
II. Does OFSCN® Offer Ceramic-Encapsulated Fiber Bragg Grating Sensors?
Yes, OFSCN® offers a series of ceramic-encapsulated Fiber Bragg Grating sensors specifically designed for high-insulation, high-temperature, and strong electromagnetic/non-magnetic environments.
Product Name: OFSCN® Ceramic-encapsulated Fiber Bragg Grating Temperature Sensor
Technical Features and Key Parameters:
  • All-dielectric non-magnetic structure: The sensing segment is encapsulated in a ceramic sleeve with high hardness and high insulation properties, completely eliminating issues related to RF eddy current heating, strong magnetic attraction, and image artifacts caused by metals.
  • Operating Temperature Range: -270°C to 800°C (excellent performance at extreme temperatures).
  • Encapsulation Size: Outer diameter typically 2.0 mm or 3.0 mm (customizable).
  • Connector Type: Commonly available with various fiber optic connectors such as FC/APC and ST/PC. The tail end can also be equipped with a non-metallic protective sheath to meet the full optical path dielectric isolation requirement.
(Note: If the measurement scenario is at room to moderate temperatures and requires flexibility, OFSCN® also offers the OFSCN® 150°C Low-Voltage Insulated Fiber Bragg Grating Temperature Sensor, based on engineering insulation materials. It has an outer diameter of approximately 1.0 mm and a temperature measurement range of -40°C to 150°C.)
