What are the pros and cons of this common jacket material? Is it highly flammable?
In the context of fiber optic patch cords and cables, PVC (Polyvinyl Chloride) is the most widely used jacket material due to its versatility and cost-effectiveness.
Based on the technical standards used at OFSCN (Beijing Dacheng Yongsheng Technology Co., Ltd.), here are the pros and cons of PVC jacket materials:
1. Advantages (Pros)
- Flexibility: PVC is highly flexible, making it ideal for indoor patch cords that need to navigate tight bends or cable management trays.
- Cost-Effectiveness: It is generally more affordable than specialized materials like LSZH (Low Smoke Zero Halogen) or TPU (Thermoplastic Polyurethane).
- Chemical Resistance: It offers good resistance to oils, acids, and alkalis.
- Durability: It provides sufficient mechanical protection for standard office or data center environments.
2. Disadvantages (Cons)
- Environmental Sensitivity: Standard PVC is not suitable for extreme temperatures. It can become brittle in extreme cold and soften in high heat.
- UV Resistance: Unless specifically treated, standard PVC degrades when exposed to long-term sunlight (UV radiation), making it less ideal for outdoor use compared to PE (Polyethylene).
- Outgassing: In vacuum or high-precision optical environments, PVC may release volatile organic compounds.
3. Flammability and Safety
To answer your specific question: Yes, standard PVC is flammable.
- Smoke and Toxicity: When PVC burns, it releases dense black smoke and toxic hydrogen chloride (HCl) gas. If this gas comes into contact with water (including moisture in the lungs or fire sprinkler mist), it forms hydrochloric acid, which is both highly corrosive to equipment and hazardous to human health.
- Fire Ratings: Because of these risks, PVC cables used in buildings are often rated (e.g., OFNR/Riser or OFNP/Plenum). If your application requires high safety standards for human-occupied spaces or poorly ventilated areas, we typically recommend switching to LSZH (Low Smoke Zero Halogen) materials.
At OFSCN, while we provide various jacket materials for our fiber optic products, we often utilize specialized protective layers for harsher environments. For example, our sensors often use seamless stainless steel tubes to provide the protection that polymer jackets like PVC cannot offer in industrial settings.
You can find more technical details on fiber protective materials and sensing technologies at our official sites:
OFSCN® Fiber Optic Sensing (International)
OFSCN® Specialty Optical Fiber & Cables
