How do water molecules and tensile forces conspire to break optical fibers?
Stress Corrosion in optical fibers, also commonly referred to as Static Fatigue in engineering and material science, is a failure process where the silica ( \text{SiO}_2 ) glass network gradually fractures due to the combined action of mechanical tensile stress (physical effect) and water molecules/moisture in the environment (chemical effect).
I. Microscopic Physical and Chemical Reaction Mechanisms
Silica glass is a brittle material composed of a robust \text{Si}-\text{O}-\text{Si} (silicon-oxygen covalent bond) network. The synergistic destructive process of water molecules and tensile stress proceeds in the following four steps:
1. Surface Microcracks and Stress Concentration (Griffith Effect)
Any optical fiber will have nanoscale surface defects or microcracks (Griffith microcracks) from the drawing, coating, or usage process. When the fiber is subjected to an external tensile load \sigma, extremely high local stress concentration occurs at the crack tip (Crack Tip) due to geometric effects:
Where a is the microcrack depth and \rho is the radius of curvature at the crack tip.
2. Mechanical Weakening of Chemical Bonds by Tensile Stress
Under the strong tensile stress at the crack tip, the \text{Si}-\text{O}-\text{Si} bond angles are forcibly opened, and the bond lengths are stretched. This mechanical deformation weakens the bond energy of the silicon-oxygen bonds and reduces the activation energy for chemical reactions, making the silicon-oxygen bonds, which are normally very difficult to react with at room temperature, highly susceptible to chemical nucleophilic attack.
3. Hydrolysis Reaction of Water Molecules (Chemical Cleavage)
Water molecules ( \text{H}_2\text{O} ) from the environment diffuse through the fiber’s polymer coating layer to the silica surface. In the activated region at the crack tip, water molecules react with the stressed silicon-oxygen bonds through hydrolysis (Charles-Hillig hydrolysis model):
The oxygen atom in the water molecule attacks the positively charged silicon atom, and a proton transfer occurs to the adjacent oxygen atom, ultimately forming two hydroxyl groups ( \text{Si}-\text{OH} ). This reaction directly cleaves the covalent bond network of the glass skeleton.
4. Subcritical Crack Growth and Final Brittle Fracture
- Dynamic Cycle: After the hydrolysis reaction cleaves the bonds, the crack tip advances by one atomic scale inwards, exposing the next layer of silicon-oxygen bonds under tensile stress; new water molecules continue to enter the tip for hydrolysis, and the crack continues to grow slowly over time (subcritical crack growth).
- Catastrophic Fracture: As the crack depth a gradually increases, the stress intensity factor K_{\text{I}} at the crack tip continuously rises. When K_{\text{I}} reaches the critical fracture toughness K_{\text{IC}} of silica (approximately 0.75\ \text{MPa}\cdot\text{m}^{1/2} ), the crack unstably propagates instantaneously at the speed of sound, leading to complete brittle fracture of the optical fiber.
II. Engineering Lifetime Prediction: Charles Power Law Model
The fracture time t_f (static fatigue lifetime) of an optical fiber under constant tensile stress typically follows a power law relationship:
- Where \sigma is the applied tensile stress;
- B is a constant related to the material, environmental temperature, and humidity;
- n is the Stress Corrosion Susceptibility Parameter.
For standard quartz fibers in ambient humid air, the value of n is typically between 18 \sim 22. Due to n being in the exponent:
- If the applied tensile stress increases by 10\%, the fiber’s service life may be reduced by more than an order of magnitude;
- If the environment completely isolates water vapor (e.g., vacuum or seamless metal tube sealing), the stress corrosion rate will significantly approach zero ( n value greatly increases).
III. Engineering Protection Measures
In engineering applications (such as fiber optic sensors and specialty optical cables), the main methods to slow down or prevent stress corrosion include:
- Controlling Long-Term Static Strain:During deployment and packaging, the fiber strain is generally controlled below 20\% \sim 30\% of its ultimate strength.
- Water Barrier and Hermetic Sealing:Employing dense polymers, metallized coatings, or seamless stainless steel tubes to physically isolate the fiber/grating, blocking the diffusion path of water molecules to the fiber glass surface.
