Why is the tailstock designed in a segmented “fishbone” shape?
In the structural design of fiber optic engineering and connectors (such as FC, SC, LC, ST, etc.), the strain relief boot (also known as a bend protection sleeve) at the connector’s end is often designed with a segmented, slotted, or “fishbone” (Ribbed / Slotted) structure. This geometric design is not merely for aesthetics but is a precise engineering choice based on material mechanics and fiber optic bending characteristics, primarily for the following reasons:
1. Implementing a Stress Relief Gradient to Eliminate Stress Concentration
Fiber optic patch cords or sensor lead wires experience a sudden change in stiffness at the root of the connector:
- The front end is the connector housing, made of metal or high-hardness engineering plastic (extremely rigid);
- The rear end is the relatively thin fiber or cable jacket (highly flexible).
If bent directly, extremely high local stress concentration would occur at the junction between rigidity and flexibility. The fishbone-like segmented structure allows the boot to exhibit a gradual flexural rigidity gradient from the root to the end:
- The root segments have smaller spacing and thicker walls, providing greater stiffness;
- The end segments have more space for movement, offering higher flexibility.
This gradient transition smoothly distributes the concentrated bending moment from a single point across the entire length of the boot, preventing sharp angular bends of the fiber at the root.
2. Mechanical Limiting Mechanism to Enforce Minimum Bend Radius (Bend Radius Limitation)
Quartz glass optical fibers are brittle. When the bend radius becomes too small, it not only causes significant macrobending loss due to the disruption of total internal reflection but also accelerates the expansion of micro-cracks on the fiber surface, leading to fatigue and fracture.
The fishbone-like structure acts as a mechanical stop:
- The depth and angle of the gaps/slots between segments are precisely calculated;
- When the boot is bent to a predetermined critical curvature, the edges of adjacent segments abut against each other, creating physical interference that limits the maximum bend of the fiber;
- This ensures that the curvature radius of the fiber always remains greater than the safe allowable threshold (e.g., the dynamic safe bend radius for conventional single-mode fibers is R \ge 30\text{ mm}) under any directional force.
3. Preventing Kinking and Permanent Bends (Anti-Kink / Anti-Snag)
In complex scenarios such as cabinet wiring, conduit installation, or sensor deployment, optical fibers are susceptible to lateral pressure or accidental pulling. The fishbone-like strain relief boot provides isotropic elastic support and resilience:
- It allows for flexible bending within its elastic limit and rapid recovery;
- It prevents permanent “kinking” at the connector exit.
4. Heat Dissipation and Material Stress Release
During molding and thermal cycling, the segmented slotted structure reduces the accumulation of internal axial stress caused by thermal expansion and contraction in a long cylindrical body. It also contributes to lightweight design and flexibility during assembly.
Summary
The fishbone-like design of the connector strain relief boot fundamentally utilizes the principles of segmented limitation and stiffness gradation. It disperses concentrated bending stress and locks in the minimum bend radius through geometric interference, thereby fundamentally preventing fiber breakage or degradation of optical signals at the connector root due to excessive bending.
