What is "optical fiber bending loss"?
Will the signal be lost if the fiber optic cable is bent too sharply?
Yes, if a fiber optic cable is bent too sharply, the signal will indeed be lost or even completely interrupted. This physical phenomenon is known in optical engineering as Bending Loss.
1. Physical Principles: Why Does Bending a Fiber Optic Cable Too Sharply Cause Signal Loss?
The ability of fiber optic cables to transmit signals at high speeds with low loss relies fundamentally on the physical phenomenon of Total Internal Reflection (TIR), which occurs at the interface between the core (Core) and the cladding (Cladding).
  • Conditions for Total Internal Reflection:
    The fiber optic’s core has a higher refractive index (let’s denote it as n_1), while the cladding has a lower refractive index (denoted as n_2). According to Snell’s Law, when light travels from a medium with a higher refractive index to one with a lower refractive index, and the angle of incidence is greater than the critical angle \theta_c (where \sin \theta_c = \frac{n_2}{n_1}), the light will not penetrate into the cladding but will be entirely reflected back into the core and continue to propagate forward.
  • Macrobending Loss:
    When the fiber optic cable undergoes a sharp bend (i.e., the bending radius is too small), the angle at which light strikes the interface between the core and cladding changes at the bend. If this angle becomes less than the critical angle \theta_c, the condition for total internal reflection is compromised. The light signal, which should have been continuously reflected within the core and propagated forward, refracts out into the cladding, is converted into a radiation mode, and eventually dissipates. The sharper the bend, the more optical power is leaked, leading to significant attenuation of the optical power, potentially resulting in complete signal loss.
  • Microbending Loss:
    In addition to macroscopically visible sharp bends, if the fiber optic cable is subjected to uneven lateral pressure at a microscopic level (such as cable structure contraction, external squeezing, or an uneven jacketing surface), causing the fiber axis to bend minutely on the micrometer scale, this can also cause coupling of the transmitted modes, leading to leakage and generating microbending loss.
2. How to Prevent Signal Loss Due to Bending in Engineering Applications?
To prevent signal loss caused by bending, engineering typically employs the following two solutions:
  1. Control the Minimum Bending Radius:
    For standard single-mode optical fibers (such as the commonly used G.652D specification), the recommended long-term static bending radius should generally not be less than 30\text{ mm}.
  2. Adopt “Bending-Insensitive Fiber” (BIF):
    This is achieved by designing a “trench” with a depressed refractive index around the core. This trench traps the light that leaks out and reflects it back into the core. Fibers conforming to the ITU-T G.657 standard (such as G.657 A2 or G.657 B3) allow for extremely small bending radii (e.g., 10\text{ mm} or even 7.5\text{ mm}), maintaining very low bending loss even in extremely compact or coiled routing spaces.
3. Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) Bending-Insensitive Fiber Technical Solutions
Beijing Dacheng Yongsheng Technology Co., Ltd. offers the following bending-insensitive fiber products that comply with standards and are resistant to harsh industrial environments. These effectively prevent signal bending attenuation in compact spaces, under vibration, and in high-temperature environments:
  • OFSCN® G.657 Optical Fiber
    Standard G.657 single-mode bending-insensitive optical fiber, with options for G.657 A2 and G.657 B3 fibers, specifically designed to provide excellent signal transmission assurance in applications requiring small bending radii.
    OFSCN® G.657 Optical Fiber Official Link
  • OFSCN® 200℃ Polyimide Optical Fiber
    Single-mode polyimide optical fiber with an operating temperature range of -60^{\circ}\text{C} to 200^{\circ}\text{C}. It can be optionally equipped with a bend-resistant core compliant with G.657 A2 and G.657 B3 standards, ensuring bending transmission performance in confined spaces and high-temperature conditions.
    OFSCN® 200℃ Polyimide Optical Fiber Official Link
  • OFSCN® 300℃ SM Polyimide Optical Fiber
    With an operating temperature range of -200^{\circ}\text{C} to 350^{\circ}\text{C}, this fiber can be optionally equipped with a bend-resistant core compliant with G.657 A2 and G.657 B3 performance standards, making it an ideal choice for bent installations in extreme cold, extreme heat, and other harsh special industrial environments.
    OFSCN® 300℃ SM Polyimide Optical Fiber Official Link
