What is the difference between Multimode and Singlemode fiber patch cords?
Why can’t the sensing system use both types of jumpers? What happens if they are connected incorrectly?
In fiber optic sensing systems, single-mode (SM) and multimode (MM) fiber optic patch cords have fundamental differences in their physical mechanisms, geometric structures, and transmission characteristics. Therefore, mixing these two types of patch cords in fiber optic sensing systems is strictly prohibited.
Mixing or incorrectly connecting these fibers in a sensing system will lead to severe optical signal attenuation, spectral distortion, and even the inability of the entire sensing system to demodulate properly. The reasons and consequences are analyzed below from the perspectives of physical principles and practical sensing applications:
I. Differences in Physical Essence: Mismatch in Fiber Core Geometric Dimensions
  • Single-Mode Fiber (SM): Has an extremely small core diameter, typically 9 μm (e.g., standard G.652D fiber), allowing only a single fundamental mode (LP_{01}) to propagate at the operating wavelength.
  • Multimode Fiber (MM): Has a larger core diameter, typically 50 μm or 62.5 μm, allowing hundreds or thousands of higher-order transverse modes to propagate simultaneously.
  • Although both typically have the same cladding diameter ( 125 μm), the core cross-sectional area differs by orders of magnitude, forming a fundamental physical barrier to compatibility.
II. What Happens When Mixed? (Physical Consequences of Two Mixing Scenarios)
Scenario 1: Multimode Patch Cord Mixed into a Single-Mode Sensing System (e.g., FBG Fiber Grating Sensing)
If a multimode patch cord is connected to a single-mode fiber-based FBG (Fiber Bragg Grating) sensing system (e.g., connecting a demodulator to a single-mode FBG sensor), the following severe consequences will occur:
  1. Massive Geometric Coupling Loss (Drastic Light Intensity Attenuation)
    • SM \to MM: Light enters a 50/62.5 μm multimode core from a 9 μm single-mode core. The coupling efficiency is relatively high, resulting in smaller losses.
    • MM \to SM: When the reflected light signal returns from a 50/62.5 μm multimode core to a 9 μm single-mode core, due to the drastic reduction in geometric cross-sectional area, most of the optical power cannot enter the single-mode core. This causes extremely high reflective coupling loss (often exceeding 15-20 dB). Consequently, the optical power returning to the demodulator falls below the instrument’s detection limit (below the noise floor), making it impossible for the demodulator to recognize the sensor.
  2. Multimode Dispersion and Spectral Distortion (Wavelength Demodulation Failure)
    • The fundamental principle of FBG sensors is based on the Bragg wavelength reflection formula:
      \lambda_B = 2 n_{eff} \Lambda
      (where n_{eff} is the effective refractive index and \Lambda is the grating period)
    • In single-mode fiber, since only the fundamental mode propagates, n_{eff} is unique, and the reflection spectrum is a very clean, sharp single peak.
    • Once a multimode patch cord is introduced, light propagates through the multimode core in multiple different modes. Different modes have different effective refractive indices (n_{eff}) and group velocities (i.e., intermodal dispersion). This leads to peak splitting, severe broadening, and phase distortion caused by multipath interference in the reflection spectrum. The fiber grating demodulator cannot accurately extract the wavelength shift, leading to complete failure of the sensing system.
Scenario 2: Single-Mode Patch Cord Mixed into a Multimode Sensing System (e.g., Raman Scattering-based Raman-DTS Distributed Temperature Sensing)
If a single-mode patch cord is connected to a distributed temperature sensing system that uses multimode fiber as the temperature-sensing medium, the consequences are equally catastrophic:
  1. Severe Limitation of Optical Power Injection: The host’s (DTS) emission laser (typically a high-power multimode laser) has difficulty coupling effectively into the 9 μm single-mode fiber core, significantly reducing the injected optical power.
  2. Loss of Backscattered Signal: Raman scattering signals (Stokes and Anti-Stokes light) are inherently extremely weak. When the weak scattered light is transmitted back to the demodulator through the single-mode patch cord, due to the extremely high loss and numerical aperture mismatch of the single-mode core, the optical power returning to the host’s detector is almost completely attenuated. The system’s signal-to-noise ratio (SNR) degrades sharply, making it impossible to demodulate the temperature distribution along the fiber.
III. Industrial Sensing Applications and Standards
In actual optical engineering, patch cords must be strictly matched to the technical specifications of the sensor and the demodulator system:
Conclusion
In fiber optic sensing systems, the type of patch cord must maintain 100% physical consistency with the sensing fiber and the optical system of the demodulator host. Mixing single-mode and multimode patch cords not only causes unacceptable coupling losses but also fundamentally destroys the optical physical characteristics of the sensing signal due to multimode interference, leading to complete system paralysis.
