Is a metal protective layer difficult to bend? Will it bend and not return to its original shape like wire?
In fiber optic sensing and cable engineering, the flexibility of the “Armor Layer” is a physical characteristic determined by both material mechanical structure and geometric dimensional parameters.
To address your questions, we can provide precise answers from the perspectives of physics and engineering structural design:
I. Is the armor layer difficult to bend?
Answer: Not difficult at all; it exhibits excellent flexibility.
The underlying physical principle is the extreme weakening of bending stiffness. According to material mechanics, the bending stiffness of a hollow tubular structure is determined by the product EI of the elastic modulus E and the area moment of inertia I. For an armored tube with a circular cross-section, an outer diameter D, and an inner diameter d, the formula for the area moment of inertia is:
I = \frac{\pi}{64} (D^4 - d^4)
Although the elastic modulus E of metals like stainless steel is relatively large (e.g., E \approx 190\text{ GPa} - 200\text{ GPa} for stainless steel), because the physical dimensions of fiber optic armor layers are compressed to a microscopic scale (e.g., the outer diameter of stainless steel tubes is typically only 0.9\text{ mm}, 2.0\text{ mm}, or even 0.6\text{ mm}, with wall thicknesses from 0.1\text{ mm} to 0.3\text{ mm}), its area moment of inertia I decays exponentially with the fourth power of its dimensions.
Consequently, its overall bending stiffness EI becomes very low, allowing it to be easily bent with a finger, feeling very soft.
II. Will it bend and not return to its original shape like a wire?
Answer: This depends on whether the bending exceeds the material’s “Elastic Limit.” Under normal operating conditions, it can automatically spring back like a coil spring.
During the process of metal material deformation under stress, there are two key stages:
- Elastic Deformation Stage: When the bending radius is greater than the critical value for the material, the internal stress within the metal material has not reached its yield strength \sigma_s. At this point, removing the external force will cause the metal tube to recover its original shape 100%, exhibiting spring-like elasticity.
- Plastic Deformation Stage: If it is forcibly bent into a sharp angle (i.e., the bending radius is too small, resulting in a permanent bend), the internal stress will exceed the yield limit. At this point, it will undergo permanent plastic deformation like ordinary wire and will no longer spring back on its own.
Critical Engineering Red Line: Minimum Bending Radius
In fiber optic communication and sensing engineering, the core purpose of limiting bending is not only to protect the metal armor layer but, more importantly, to protect the fragile silica glass optical fiber inside.
- If the bending radius is too small, not only will the metal tube undergo permanent plastic deformation, but the internal optical fiber will also experience severe signal attenuation due to Macrobending Loss, or even physical breakage.
- Therefore, when laying and using armored fiber optic cables, the minimum bending radius constraint must be adhered to (typically, a static bending radius is recommended to be no less than 10 to 20 times the outer diameter of the cable).
III. OFSCN® (Beijing Dacheng Yongsheng Technology Co., Ltd.) Related Armored Technology Products
Beijing Dacheng Yongsheng Technology Co., Ltd. utilizes precision seamless stainless steel tubes and special “elastic alloy” technology to balance the “mechanical protection strength” with the “bending flexibility” of the armor layer.
1. Elastic Alloy Encapsulation (with excellent elastic recovery capabilities)
For strain measurement scenarios requiring high-frequency, repetitive stretching and bending, Beijing Dacheng Yongsheng Technology Co., Ltd. has developed sensors encapsulated in elastic alloy tubes. These alloys possess higher yield strength and elastic limits than ordinary stainless steel, ensuring excellent elastic recovery characteristics for the sensor under minor strains, thereby avoiding “bend-and-not-return” plastic deviations:
OFSCN® 85°C OFDR Micro All-Metal Strain Sensor (Outer diameter only 0.6\text{ mm}, with excellent flexible bending and elastic recovery properties)
2. Ultra-fine Stainless Steel Seamless Tube Armoring (High strength balanced with flexibility)
For general-purpose distributed fiber optic sensing or fiber optic patch cords, ultra-thin-walled seamless stainless steel tubes are used for protection. While ensuring tensile strength (e.g., \gt 1200\text{ N}), their extremely fine tube diameter still maintains excellent bending flexibility for easy installation and deployment:
In summary, micro/millimeter-scale metal armor protective layers are very light and easy to bend; within reasonable bending radii, they possess elastic recovery capabilities similar to springs and do not easily undergo permanent deformation like ordinary stiff wire.
