What is the "flexibility rating"?
How do we quantify how “soft” a patch cord is? What are the grading standards?
In the realm of fiber optic communication and sensing engineering, there is no single quantifiable metric directly named ‘Flexibility Rating’ within international or industry standards.
What is commonly discussed in daily engineering as the “softness or hardness” of a patch cord is scientifically quantified and graded through three dimensions: bending stiffness (mechanical perception), repeated flex endurance (mechanical durability), and allowable bend radius with macrobending loss (optical limits), as per material mechanics and optical engineering principles.
I. How to Quantify the “Softness” and “Hardness” of a Patch Cord?
1. Mechanical Quantification: Bending Stiffness (EI)
The perceived “softness” and “hardness” in hand is essentially the bending stiffness EI of the patch cord’s cross-section:
  • E represents the equivalent Young’s Modulus of the constituent materials.
  • I is the Moment of Inertia of the patch cord’s cross-section. For solid/concentric tubular structures, the moment of inertia is proportional to the fourth power of the outer diameter (I = \frac{\pi (D^4 - d^4)}{64}).
A thinner patch cord or one with a lower modulus sheath material (e.g., polymers like PVC, TPU) will have a smaller bending stiffness EI, making it more pliable and easier to bend. Conversely, if the internal structure includes rigid metallic conduits (such as seamless stainless steel capillary tubes or stainless steel wire rope armor), the modulus E significantly increases (stainless steel’s elastic modulus is tens to hundreds of times higher than that of polymer materials), greatly increasing the resisting torque during bending, which is perceived as “stiffer”.
2. Durability Quantification: Dynamic Flex Fatigue Testing (IEC Standards)
To measure the patch cord’s ability to withstand prolonged bending and swinging, standards like IEC 60794-1-21 are typically followed:
  • Flexing Test (Method E8): Under a specified load, the patch cord is repeatedly bent to \pm 90^\circ (often requiring thousands to tens of thousands of cycles). The test checks for mechanical cracking of the outer jacket, breakage of the internal fiber core, and whether the optical power attenuation variation \Delta\alpha exceeds the limit.
  • Bend Test (Method E11): Evaluates the mechanical and optical integrity of the patch cord after being wound around mandrels of various diameters.
3. Optical Performance Grading: Macrobending Loss Rating (ITU-T Standards)
The optical fiber itself inside the patch cord has bending radius limitations. The International Telecommunication Union Telecommunication Standardization Sector (ITU-T) has established grading standards for the bend performance of single-mode fibers (ITU-T G.657 and G.652):
Fiber Standard Category Nominal Minimum Allowable Bend Radius Typical Applications & Macrobending Characteristics
ITU-T G.652.D R \ge 30\text{ mm} Standard single-mode fiber; macrobending loss increases significantly when the bend radius is less than 30\text{ mm}.
ITU-T G.657.A1 R \ge 10\text{ mm} Bend-insensitive fiber, maintains low additional loss at a 10\text{ mm} radius.
ITU-T G.657.A2 / B2 R \ge 7.5\text{ mm} Suitable for high-density cabling and tight turns in confined spaces like equipment racks.
ITU-T G.657.B3 R \ge 5\text{ mm} Ultra-high bend resistance, can withstand extremely tight coiling at a 5\text{ mm} radius.
II. Classification of Patch Cords by Structure based on “Stiffness/Flexibility” in Practical Engineering
Based on internal structural design, fiber optic patch cords typically strike a balance between “absolute flexibility” and “resistance to external damage”:
1. Traditional Flexible Patch Cords (High Flexibility)
These patch cords use a conventional polymer outer jacket reinforced with aramid fibers (Kevlar), without an internal rigid metal layer. They are extremely soft and highly compliant, suitable for patch panels in data centers or mild environments, but possess lower tensile strength and resistance to gnawing.
Reference Product:
2. Micro-Armored and Steel Wire Rope Armored Patch Cords (Balancing Flexibility with High Mechanical Strength)
To prevent damage from being stepped on, run over, or crushed in outdoor or harsh industrial environments, patch cords are often encapsulated with micro-stainless steel tubes or galvanized steel wire rope structures. While their bending stiffness is higher than traditional soft patch cords, they still maintain an elastic degree of bend and can withstand compressive forces in the hundreds of megapascals.
Reference Products:
  • Steel Wire Rope Stranded Structure: Features an outer layer of 0.45\text{ mm} steel wire rope stranded over an inner stainless steel tube, combined with G.657 bend-resistant fiber. It offers a tensile strength > 1200\text{ N} and compressive strength > 200\text{ MPa}:
    OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord
Summary
To assess the “softness/flexibility” of a patch cord, one should consider:
  1. The cross-sectional bending stiffness EI, determined by the sheath and internal armor materials (perceived softness/hardness).
  2. The number of bending cycles under the IEC 60794-1-21 standard (fatigue resistance).
  3. The allowable bend radius adhered to by the fiber (ITU-T G.652.D / G.657.A1 / A2 / B3) (optical performance limit).
