What is the micro-bending effect?
Why does minor squeezing cause a significant reduction in optical signals?
In optical engineering, the Micro-bending Effect is a classic phenomenon in physics and waveguide transmission. The reason why the “slight squeezes” you mentioned cause significant attenuation of optical signals lies in the core physical mechanism of mode coupling and energy leakage in optical waveguides.
Here is an academic analysis from the perspectives of physical principles and engineering solutions:
I. Physical Mechanism: Why Do Slight Squeezes Cause Significant Light Signal Attenuation?
In an ideal single-mode optical fiber, light relies on the refractive index difference between the core and the cladding to form total internal reflection, being perfectly confined within the core and propagating forward as a Guided Mode (or fundamental mode).
When the fiber experiences tiny, non-uniform lateral squeezes (such as rough contact surfaces, uneven shrinkage of the coating, or minor mechanical disturbances), the fiber axis generates micro-scale amplitude, millimeter-period high-frequency bends. Although these bends are small, they disrupt the waveguide’s original boundary conditions, triggering the following physical processes:
  1. Mode Coupling:
    Tiny local geometric distortions alter the electromagnetic field boundary within the fiber. In electromagnetic waveguide theory, such perturbations cause the fundamental mode, originally propagating in the core, to couple with cladding modes or radiation modes within the fiber cladding. A portion of the optical energy is transferred from the fundamental mode to these higher-order modes.
  2. Irreversible Energy Loss:
    Cladding modes are not confined within the core. Since the outermost layer of the fiber is typically covered with a protective coating layer of higher refractive index (such as polyacrylate or polyimide), the optical energy coupled into the cladding is absorbed by the coating or radiates outwards after propagating a very short distance, rendering it unable to return to the core. On a macroscopic scale, this manifests as severe optical power attenuation.
Key Control Variables:
From a theoretical characterization standpoint, the additional attenuation coefficient \alpha_{mb} caused by fiber micro-bending is generally closely related to the fiber’s relative refractive index difference \Delta. The attenuation coefficient \alpha_{mb} is inversely proportional to \Delta. Therefore, increasing the refractive index difference between the core and cladding, or reducing the fiber’s Mode Field Diameter (MFD), can significantly enhance the fiber’s resistance to the micro-bending effect.
II. How to Address Micro-bending Effects in Engineering Applications?
In precision distributed sensing and Fiber Bragg Grating (FBG) sensing, micro-bending effects caused by squeezing directly reduce the system’s demodulation signal-to-noise ratio. To address this issue, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN®) offers a product series with high resistance to bending and micro-bending:
1. Selecting High-Performance Bend-Insensitive Fibers
To maintain optical signal strength in environments with multiple bends and susceptibility to squeezing, optimization of the fiber structure design is essential (e.g., by adding a Trench refractive index depressed ring):
  • Product Name: OFSCN® G.657 Optical Fiber
  • Technical Specifications and Advantages: This product is a standard G.657 single-mode bend-insensitive optical fiber (optional G.657 A2 or G.657 B3 for extremely high bend resistance grades). Its core structure strongly confines the optical field, minimizing the coupling of the fundamental mode to cladding modes even when the fiber is subjected to minor lateral pressure or experiences physical bends of very small radii, thereby effectively suppressing micro-bending attenuation.
2. Application in Fiber Bragg Grating (FBG) Sensors
When Fiber Bragg Gratings are surface-bonded or embedded within structures, glue curing shrinkage or local material squeezing can easily induce micro-bending. OFSCN® has specifically launched bare grating products manufactured using bend-insensitive fibers:
  • Product Name: OFSCN® Polyacrylate Fiber Bragg Gratings / FBG Strings (Bare)
  • Technical Specifications and Advantages: This series of bare gratings and FBG strings can be optionally written and re-coated using standard OFSCN® G.657 fibers. This ensures that the Fiber Bragg Gratings are not affected by energy loss caused by local micro-bending during complex sensor packaging and various physical field installations, guaranteeing clarity and stability of the reflected spectral peaks.
