What is the refractive index profile design of an optical fiber?
How can we control the light propagation by changing the number of glass layers?
In fiber optics, the process of precisely controlling the propagation path and distribution pattern of light waves within the core by altering the number of structural layers of silica glass and the silica doping amount in each layer (i.e., controlling the refractive index n in different regions) is known as Refractive Index Profile Design.
The fundamental physical mechanisms for light propagation within glass are Total Internal Reflection (TIR) and waveguide mode confinement. By increasing or modifying the number of glass layers and the refractive index distribution, light propagation behavior (the “way light travels”) can be modulated in the following dimensions:
1. Two-Layer Glass Structure (Single Cladding Structure): Achieving Basic Light Guiding
  • Structural Components: Central core (High-Index Core, refractive index n_1) + outer cladding (Low-Index Cladding, refractive index n_2), with n_1 > n_2.
  • Light Propagation Control: When light in the core strikes the interface between the core and cladding at an angle greater than the critical angle \theta_c, it cannot transmit into the cladding. Instead, it propagates forward in a “zigzag” (segmented) path within the core via total internal reflection. This is the most basic propagation mode for standard single-mode and step-index multimode fibers.
2. Graded-Index Multilayer Structure: Bending Light Paths to Eliminate Time Delay Differences
  • Structural Components: The core consists of multiple layers of silica glass with varying doping concentrations (e.g., germanium dioxide \text{GeO}_2), causing the refractive index to decrease continuously in a parabolic profile from the central axis outwards.
  • Light Propagation Control: Light does not undergo abrupt total internal reflection during propagation. Instead, it follows a continuous refraction path, bending in a sinusoidal wave-like pattern.
    • Light traveling straight along the axis takes a shorter physical path but travels at a slower speed due to the high refractive index at the center.
    • Light deviating along the sinusoidal curve travels a longer physical path but at a faster speed due to the lower refractive index at the edges.
      Through this fine-tuning of the multilayer refractive index, light rays entering at different angles arrive at the destination almost simultaneously, significantly reducing Intermodal Dispersion.
3. Three-Layer and Multilayer Cladding Structures (Depressed Cladding / Trench-Assisted Structure): Limiting Light Energy Leakage and Enhancing Bend Insensitivity
  • Structural Components: Between the core and the outer cladding, an additional layer of low-refractive-index glass, doped with elements like fluorine (\\text{F}), is introduced, forming a Depressed Cladding / Trench-Assisted Structure. The refractive index distribution satisfies: Core n_1 > Outer Cladding n_2 > Depressed Cladding n_3.
  • Light Propagation Control: When the optical fiber is subjected to severe bending, portions of higher-order modes or electromagnetic fields at the boundary can leak into the cladding, causing optical power loss. The intermediate low-refractive-index “trench” layer acts as a potential barrier for light waves, enhancing the rebound and confinement of leakage modes into the cladding. This effectively “locks” the light intensity firmly within the core, achieving excellent bend-insensitive characteristics.
Official Product Series
In the OFSCN® official product series, based on different refractive index profile designs and glass layer controls, various technical products have been developed for different operating conditions:
  1. OFSCN® G.652D Optical Fiber
    Employs a standard single-mode step-index refractive profile design, meeting the requirements for conventional long-distance low-loss transmission.
  2. OFSCN® G.657 Optical Fiber
    Utilizes a trench-assisted multilayer cladding refractive index profile design, significantly reducing bending loss. It is suitable for fiber sensing and transmission in miniaturized packages and environments with complex bends.
