What is the significance of the text printed on the cable jacket?
What performance characteristics do codes like “G.652D” or “G.657A” represent in international standards?
The codes “G.652D” and “G.657A” refer to international standards defined by the ITU-T (International Telecommunication Union - Telecommunication Standardization Sector). These standards specify the geometric, optical, and transmission characteristics of single-mode optical fibers.
In the context of DCYS (OFSCN) products, these codes represent the performance limits of the internal fiber core used within our specialized sensors and cables.
1. G.652D (Standard Single-Mode Fiber)
G.652D is the most common single-mode fiber used globally. Its primary characteristics include:
  • Zero Dispersion Wavelength: Around 1310 nm. It is also optimized for transmission at 1550 nm.
  • Low Water Peak: The “D” variant indicates that the fiber is manufactured to eliminate the high attenuation caused by hydroxyl (OH-) ions at the 1383 nm wavelength, allowing for a broader usable spectrum.
  • Application: It is the standard core for many of our general-purpose products, such as the OFSCN® G.652D Optical Fiber.
2. G.657A (Bending-Insensitive Fiber)
G.657A is functionally compatible with G.652D but is specifically designed for better performance under tight bends.
  • Macro-bend Loss: This fiber significantly reduces signal loss when the fiber is curved or coiled with a small radius.
  • Variants (A1/A2): G.657A2, for example, allows for a much smaller minimum bend radius compared to standard G.652D, making it ideal for compact sensors or complex installations where space is limited.
  • Application: We use this in products requiring high flexibility or compact packaging, such as the OFSCN® G.657 Optical Fiber.
Why this matters for FBG Sensors and Cables
When selecting an OFSCN® product, the fiber type affects how the signal behaves during installation:
  • For Long-Distance Sensing: G.652D is typically preferred for its stable transmission characteristics.
  • For Miniature Sensors: G.657A is often chosen to ensure that the Fiber Bragg Grating (FBG) signal remains strong even if the sensor housing or lead-in cable undergoes sharp bending.
For example, our OFSCN® Polyacrylate Fiber Bragg Gratings can be manufactured using either G.652D or G.657 fiber cores depending on your specific integration requirements.
If you are designing a sensing system, understanding whether your installation environment involves tight corners will determine which of these standards you should specify for your cable or sensor lead.
