Would glass, a “supercooled liquid,” flow and deform over a long period?
In condensed matter physics and optical engineering, quartz glass optical fibers do not undergo macroscopic “flow” or deformation at room or normal operating temperatures. The notion that “glass is a supercooled liquid that flows over time” is a widespread and persistent misconception in classical physics.
I. Physical Mechanisms and Thermodynamic State Analysis
Amorphous Solid, Not a Macroscopically Flowing Liquid:
The primary material of optical fibers is high-purity silicon dioxide (\text{SiO}_2). Although its atomic arrangement lacks long-range order at the microscopic level (exhibiting a disordered network structure similar to liquids), thermodynamically and mechanically, glass silica possesses a fixed shear modulus and rigidity, classifying it as an amorphous solid. -
Extremely High Viscosity and Ultra-Slow Relaxation Times:
- The glass transition temperature (T_g) for pure silica glass is approximately 1100\ ^\circ\text{C} \sim 1200\ ^\circ\text{C}, with its softening point above 1600\ ^\circ\text{C}.
- At room temperature (around 20\ ^\circ\text{C} \sim 25\ ^\circ\text{C}), the theoretical viscosity of pure quartz glass far exceeds 10^{20}\ \text{Pa}\cdot\text{s}.
- Based on the Arrhenius equation and viscoelastic relaxation models, the timescale required for quartz glass to exhibit measurable flow under gravity or slight stress at room temperature far surpasses the current age of the universe (billions of years).
(Note: Historical anecdotes about medieval European stained glass windows becoming “thicker at the bottom” have been disproven by modern material analyses, which attribute this to the manufacturing inconsistencies of the time and assembly practices, not long-term gravitational flow.)
II. Actual Physical Factors Affecting Fiber “Structural Stability”
In fiber optic sensing and communication engineering, the geometric structure of the quartz glass core and cladding is extremely stable. The factors that genuinely lead to long-term degradation of a fiber’s dimensions, morphology, or optical performance primarily include:
- Thermal Aging and Creep of the Coating Material:
The outermost protective layer of an optical fiber is typically a polymer (such as standard polyacrylate, polyimide, etc.) or a metallic layer. Polymer coatings can undergo physical aging, creep, and degradation under conditions of elevated temperature, humidity, or sustained strain. This is often the precursor to mechanical protection failure, rather than deformation of the quartz material itself. - Stress Relaxation and Dopant Diffusion at Extreme Temperatures:
When optical fibers operate in extreme high-temperature environments (above 800\ ^\circ\text{C} \sim 1000\ ^\circ\text{C}), frozen-in residual stresses within the quartz material begin to relax. Dopant elements (such as Germanium \text{Ge}, Fluorine \text{F}, etc.) in the fiber core can undergo thermal diffusion, leading to distortion of the refractive index profile and degradation of the optical waveguide structure. - Static Fatigue and Stress Corrosion:
When optical fibers are subjected to sustained mechanical tensile stress and exposed to moisture/chemical environments, the microscopic crack tips on the quartz surface undergo hydrolytic cleavage of chemical bonds (subcritical crack growth), ultimately leading to brittle fracture. This is a failure mechanism driven by the combined action of chemistry and mechanics, not rheological deformation.
Conclusion
Within its normally designed operating temperature range, quartz optical fiber exhibits high long-term dimensional and morphological stability due to its glass network structure, and the issue of fiber deformation caused by “supercooled liquid flow” does not occur. The key considerations for designing the long-term stability of optical fiber structures lie in coating durability, interfacial stress transfer, and moisture barrier protection.
