Why 1550 nm?
Why is this specific wavelength the most popular choice for fiber optic sensing? Does it hold a special status in the industry?
The choice of 1550 nm as the predominant wavelength for Fiber Bragg Grating (FBG) sensing is not arbitrary; it is driven by the physical properties of silica optical fiber and the historical development of the telecommunications industry.
As an engineer at OFSCN (Beijing Dacheng Yong Sheng Technology Co., Ltd.), I can categorize the reasons into three primary technical factors:
1. Minimal Attenuation (The “Third Window”)
Silica-based optical fibers exhibit their lowest signal loss (attenuation) in the C-band, centered around 1550 nm. The attenuation is typically as low as 0.2 dB/km.
  • Significance for Sensing: This allows FBG sensors to be placed kilometers away from the interrogator without significant signal degradation, making it ideal for large-scale structural health monitoring (e.g., bridges, tunnels, and long-distance pipelines).
2. Industry Standardization and Ecosystem
The 1550 nm wavelength is the backbone of global telecommunications. Because of this:
  • Component Availability: High-quality, reliable, and cost-effective components—such as tunable lasers, ASE light sources, optical couplers, and circulators—are mass-produced for the 1550 nm band.
  • Interrogator Compatibility: Most Fiber Bragg Grating Interrogators (demodulators) are designed to operate in the 1525 nm to 1565 nm range (C-band) to leverage these mature technologies.
3. Material Science and Stability
At 1550 nm, the interaction between light and the germanium-doped core of the fiber is highly stable. Fiber Bragg Gratings written for this wavelength maintain excellent thermal and mechanical stability, which is critical for the precision sensors we produce at DCYS.
OFSCN® Product Implementation
At OFSCN, we utilize the 1550 nm standard across our core sensor lines to ensure maximum compatibility with international monitoring systems.
For example, our OFSCN® Capillary Seamless Steel Tube Packaged FBG Temperature Sensors are optimized for the 1550 nm band, allowing for high-sensitivity measurements even in harsh environments.
Standard Product Image:
Related Product Links:
While 1550 nm is the “Golden Standard,” other wavelengths (like 850 nm or 1060 nm) are sometimes used for specialized, short-distance medical or laboratory applications where fiber cost is less critical than specific physical constraints. However, for industrial sensing, 1550 nm remains the undisputed leader.
