What do the different jacket colors represent? Can I simply purchase any color and expect it to work in my system?
The color of a fiber optic patch cord jacket is not merely aesthetic; it follows specific industry standards (such as TIA-592) to indicate the type of optical fiber inside and its transmission characteristics.
1. What do the different jacket colors represent?
The most common color coding for non-military applications includes:
- Yellow: Represents Single-Mode Fiber (SM), typically G.652D or G.657. It is used for long-distance communication as it has a small core (9µm) that allows only one mode of light to propagate.
- Orange: Typically represents Multimode Fiber (MM), specifically OM1 (62.5/125µm) or OM2 (50/125µm).
- Aqua (Teal): Represents Laser-optimized Multimode Fiber (OM3 or OM4), designed for 10Gb/s, 40Gb/s, and 100Gb/s Ethernet over shorter distances.
- Lime Green: Often used for OM5 (Wideband Multimode Fiber).
2. Can you simply purchase any color?
No. You cannot mix and match different colors/fiber types.
- Incompatibility: If you connect a yellow (Single-mode) patch cord to a system designed for multimode fiber (or vice versa), the mismatch in core diameters (9µm vs 50/62.5µm) will cause massive signal loss, and the system will likely not function.
- Light Source: Your equipment (SFP modules, lasers, or OFSCN® Fiber Bragg Grating Interrogators) is designed for a specific fiber type. You must match the patch cord to the specifications of your active equipment.
3. Special Environment Considerations
In industrial or sensing applications, color coding may differ because the jacket material becomes more important than the standard color. For example:
- For standard laboratory or data center use, we provide the OFSCN® Standard Fiber Patch Cord, which typically uses the standard yellow PVC jacket for single-mode fiber.
- In high-temperature environments, color is often sacrificed for durability. Our OFSCN® 300℃ Fiber Optic Patch Cord uses a stainless steel seamless tube instead of a colored plastic jacket to survive extreme conditions.
Standard Product Reference:
When selecting a patch cord, always verify the Fiber Type (SM or MM) and the Connector Type (e.g., FC/APC) required by your hardware rather than relying solely on the jacket color.
