It is only 9 microns wide—how do you even manage to “shoot” light into such a tiny core?
The thin core of a single-mode fiber (typically 9 microns for standard G.652 fiber) is a fundamental design requirement dictated by the physics of light propagation.
1. The Physics: Why it must be thin
The primary reason for such a small core is to ensure that only a single mode (the fundamental mode, LP_{01}) of light can propagate.
In fiber optics, the number of modes is determined by the V-number (Normalized Frequency):
- Where a is the core radius, \lambda is the wavelength, and n represents refractive indices.
- To achieve single-mode operation, V must be less than 2.405.
If the core were larger (like in multi-mode fiber, which is 50 or 62.5 microns), different “paths” or modes of light would travel at different speeds, causing intermodal dispersion. This would smear the signal over long distances, limiting bandwidth. By keeping the core at 9 microns, we eliminate intermodal dispersion entirely, allowing for high-speed, long-distance transmission.
2. How do we “shoot” light into it?
You are right to wonder—aligning a light source to a 9-micron target is a significant engineering feat. It is managed through several specialized techniques:
- Pigtail Laser Diodes: In most OFSCN® systems, the laser source is factory-aligned to a short piece of fiber (a pigtail) using automated high-precision stages. The laser chip is physically “welded” into place once the maximum power output is detected at the fiber end.
- Active Alignment: When connecting two fibers, we use Fusion Splicers. These devices use built-in cameras and motors to align the fiber cores with sub-micron precision before melting the glass together with an electric arc.
- Precision Connectors: Standard connectors (like LC or FC/APC) use high-precision ceramic ferrules. These ferrules have a center hole accurate to within 1 micron, ensuring that when two connectors “click” together, the 9-micron cores line up accurately.
- Expanded Beam Technology: In some harsh environments, lenses are used to expand the light from the 9-micron core into a much larger beam before it crosses a gap, then focus it back down into the next fiber.
OFSCN® Applications
At Beijing Dacheng Yongheng Technology, we utilize these principles to manufacture high-accuracy sensors. For instance, our Fiber Bragg Grating (FBG) Sensors rely on the consistency of this 9-micron core to reflect specific wavelengths of light for precise temperature and strain measurements.
Whether it is for the OFSCN® Capillary Seamless Steel Tube Series or specialized sensing, the “thinness” of the core is what enables the high sensitivity and low signal loss our products are known for.
For more technical details on fiber structures, you can explore:
Specialty Optical Fibers and Cables
