Problem Description
This discussion addresses a crucial question regarding the reliability of Fiber Bragg Grating (FBG) sensing systems: If an optical fiber with multiple FBG sensors connected in series breaks in the middle, will all subsequent sensors become completely ineffective?
Technical Analysis
In a series-connected Fiber Bragg Grating (FBG) sensing system, the working principle relies on the continuous transmission and reflection of light. A broadband light signal from a demodulator travels along the fiber, passing through each FBG sensor, which then reflects specific wavelengths back to the demodulator.
If the optical fiber suffers a break at any point before or between sensors, the light path is interrupted.
- Sensors after the break: The light emitted by the demodulator cannot reach these sensors, thereby preventing them from reflecting any signals. Consequently, all sensors located downstream from the break will cease to function.
- Sensors before the break: If there are any FBG sensors located upstream from the break, their reflected light remains unaffected and can still return to the demodulator via the intact fiber segment.
This scenario highlights an inherent characteristic of serial sensing architectures: the risk of a single point of failure. A single break can compromise a significant portion or even the entirety of the monitoring chain beyond the point of failure.
Solution & Recommendation
OFSCN (Beijing Dacheng Yongsheng Technology Co., Ltd.) offers comprehensive solutions and recommendations to mitigate the risk of fiber breaks and ensure system reliability:
- Robust Encapsulation Technology:
OFSCN employs advanced and highly durable encapsulation technologies to protect the optical fiber. This includes OFSCN® alloy tube packaging, customizable for high-temperature resistance up to 300℃, and OFSCN® polymer material + seamless steel tube composite packaging, which provides superior waterproofing, moisture resistance, and mechanical strength with outer diameters up to 2.3mm. These protective measures significantly reduce the likelihood of physical damage to the fiber in harsh environments. - Optimized Optical Path Design:
For critical applications demanding exceptionally high reliability, consider implementing ring or redundant wiring schemes. These designs ensure that even if one segment of the fiber breaks, the optical signal can still reach the sensors or return to the demodulator via an alternative path. While this approach may increase wiring complexity and cost, it offers enhanced fault tolerance and is evaluated based on specific project requirements. - Meticulous Installation and Protection:
During on-site installation, OFSCN recommends and provides specialized OFSCN® installation fixtures. Through careful routing, protective sleeving, and avoiding sharp bends, the integrity of the fiber link is further safeguarded against potential damage. - Multi-Fiber Multi-Channel Systems:
For applications involving a large number of monitoring points or requiring high redundancy in specific areas, OFSCN can design parallel systems featuring multiple optical fibers and demodulator channels. In such configurations, each fiber is responsible for monitoring a portion of the area or different types of parameters. This design ensures that damage to one fiber does not affect the operation of the entire sensing system.
Recommended Product
- OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor: Fiber Bragg Grating strain sensor - FBG strain gauge - 6000με - High Temperature FBG Strain Sensor - picture parameter customization - manufacturer brand price - DCYS - ofscn.net
- OFSCN® Polymer Packaged Fiber Bragg Grating Strain Sensor (1.5mm/2.3mm diameter): https://www.ofscn.net/fbg-products/strain-sensor-2.html
- OFSCN® Installation Fixtures: Installation Fixtures - FBG Sensor - FBG Strain Stress Displacement Pressure - Bolt/Welding/Gluing/Surface Mounting/Binding/Clamp Engineering Installation Methods Pictures - Manufacturer Brand Price - DCYS - ofscn.net
(Source Discussion / 原帖讨论: 光纤中间断裂,传感器测点会全失效吗?)
