Product Aliases: Fiber optic thermometer, Fiber Optic Grating Temperature Sensor, FBG Thermometer, Temperature Sensor, Temperature Probe, Thermometer, Temperature Gauge, Fiber Bragg Grating Probe, FBG Probe, Fiber Optic Temperature Sensor, Grating Temperature Sensor, Optical Fiber Temperature Sensor, Industrial Fiber Optic Thermometer, Stainless Steel FBG Sensor, Distributed Temperature Sensor, Quasi-Distributed Temperature Sensor, OFSCN Temperature Sensor, 100℃ FBG Sensor.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/temperature-sensor-100.html
The OFSCN® 100°C Fiber Bragg Grating Temperature Sensor is a specialized optical sensor designed for precise temperature monitoring in environments ranging from -40°C to +100°C. Unlike traditional electronic sensors, it utilizes Fiber Bragg Grating (FBG) technology, making it immune to electromagnetic interference (EMI) and suitable for long-distance signal transmission.
Key Technical Specifications:
- Encapsulation: Single-layer seamless steel tube for robust protection.
- Dimensions: Default outer diameter of 0.9 mm (customizable down to 0.6 mm).
- Temperature Range: -40°C to +100°C.
- Measurement Points: Can be produced as a single-point sensor or a multi-point (quasi-distributed) sensor string. When used with a 40nm FBG interrogator, up to 20 points per string are supported.
- Connector Type: Default FC/APC (customizable to ST, LC, SC; PC or APC).
Product Visuals:
Advantages of the OFSCN® Design:
The seamless steel tube packaging ensures high mechanical strength and excellent thermal conductivity while protecting the delicate fiber core. This model is ideal for industrial temperature monitoring where moisture, corrosion, or high voltage might interfere with conventional electrical thermometers.
For detailed technical parameters and data sheets, you may visit the official product page:
