Why 1310 nanometers (nm)?
Compared to 1550 nm, what are the advantages and disadvantages of this wavelength in terms of transmission distance?
In the fields of single-mode optical fiber communication and fiber optic sensing, 1310 nanometers (nm) and 1550 nanometers (nm) are the two most mainstream working wavelengths. Their advantages and disadvantages in transmission distance are primarily constrained by two physical effects: fiber loss (attenuation) and dispersion (pulse broadening).
Below is a multi-dimensional academic comparison of these two wavelengths in terms of transmission distance and system design:
I. Attenuation and Loss (Determining “Loss-Limited” Transmission Distance)
As optical signals propagate through optical fiber, their energy decays exponentially with distance (unit: dB/km). This attenuation determines the maximum physical distance the signal can travel without optical amplification.
  • Advantage of 1550 nm (Lowest Loss Window):
    • In standard silica (quartz) single-mode optical fiber, 1550 nm resides in the fiber’s third lowest loss window, with a typical attenuation as low as 0.18 dB/km to 0.25 dB/km.
    • Transmission Distance Performance: Due to minimal loss, 1550 nm optical signals can easily travel 80 km to 120 km or more without repeaters or amplifiers, making it the preferred wavelength for ultra-long-haul backbone networks and submarine cables.
  • Disadvantage of 1310 nm:
    • 1310 nm is located in the fiber’s second lowest loss window, with a typical attenuation of approximately 0.32 dB/km to 0.40 dB/km.
    • Transmission Distance Performance: Limited by the combined effects of Rayleigh scattering and infrared absorption, at the same transmission power, 1310 nm attenuates nearly twice as fast as 1550 nm in optical fiber. Consequently, its non-repeatered transmission distance is usually confined to within 40 km (typically 10 km to 40 km for metropolitan area networks or local area networks).
II. Dispersion Characteristics (Determining “Dispersion-Limited” Transmission Distance and System Complexity)
As transmission distance increases, optical pulses broaden due to differences in group velocity among various frequency components or modes (i.e., dispersion), leading to overlapping adjacent pulses (Inter-Symbol Interference), which limits the system’s maximum transmission bandwidth and unrepeated distance.
  • Advantage of 1310 nm (Zero Dispersion Wavelength):
    • For the classic OFSCN® G.652D Optical Fiber single-mode fiber, its zero dispersion wavelength falls precisely around 1310 nm (between 1300 nm and 1324 nm).
    • Transmission Distance Performance: When transmitting at this wavelength, optical pulses experience almost no dispersion broadening. This means that for high-speed transmission over tens of kilometers at medium distances, the system requires no dispersion compensation (DCM), greatly simplifying system design and reducing the chip and packaging costs of optical modules.
  • Disadvantage of 1550 nm:
    • Although it has the lowest loss, 1550 nm exhibits a significant dispersion coefficient in standard single-mode fiber, typically around +17 ps/(nm·km).
    • Transmission Distance Performance: For high-speed (e.g., 10 Gbps or higher) long-distance transmission, dispersion causes severe signal distortion after tens of kilometers. Therefore, ultra-long-distance transmission systems using 1550 nm must incorporate complex dispersion-shifted fibers (G.653), non-zero dispersion-shifted fibers (G.655), or use dispersion compensation modules (DCM) and coherent digital signal processing (DSP) techniques at the receiver/line. This increases the physical difficulty and equipment cost of system setup.
III. Optical Amplifier Compatibility (Determining Ultimate Network Distance)
For ultra-long-distance transmission spanning thousands of kilometers, signals must be amplified along the route.
  • Absolute Advantage of 1550 nm:
    • 1550 nm perfectly matches the gain medium wavelength of Erbium-Doped Fiber Amplifiers (EDFA). EDFAs are highly mature, low-noise, high-gain all-optical amplifiers. By cascading EDFAs along the line, the transmission distance for 1550 nm signals can be extended to thousands of kilometers without the need for complex “optical-electrical-optical” regeneration repeaters.
    • The 1310 nm band lacks efficient and cost-effective commercial all-optical amplifiers like EDFAs. While Semiconductor Optical Amplifiers (SOA) or Raman amplifiers can be used, SOAs suffer from large nonlinear effects, high noise, and gain saturation, making them difficult for long-distance, multi-stage cascaded amplification.
Summary and Application Scenario Comparison
Characteristic 1310 nm Wavelength 1550 nm Wavelength
Typical Attenuation Approx. 0.35 dB/km (Higher) Approx. 0.20 dB/km (Very Low)
Dispersion Characteristics (G.652D) Near-Zero Dispersion (Low dispersion limitation) Approx. 17 ps/(nm·km) (Severe dispersion limitation, compensation required)
Unrepeated Limit Distance Approx. 40 km (Loss-limited) Up to 100 km+ (Dispersion-limited, can be further with compensation)
Optical Amplifier Support SOA / Pr-doped amplifier (Difficult for long-haul cascading) EDFA (Easy all-optical amplification, supports thousands of kilometers)
Typical Application Fields Metropolitan Area Networks, Local Area Networks, Fiber to the Home (FTTH), Short-distance Sensors Long-haul Backbone Networks, Submarine Cables, Large-scale Distributed FBG Sensing Systems
OFSCN® Related Product Support
In actual optical fiber transmission and high-precision sensing applications, to maintain stable physical properties under extreme industrial or scientific environments (such as high or low temperatures), high-quality, standardized fiber optic substrates are required.
OFSCN® provides high-temperature single-mode optical fibers based on standard G.652D production, which perfectly support the transmission requirements of both 1310 nm and 1550 nm dual wavelengths:
  1. OFSCN® G.652D Optical Fiber: Standard single-mode fiber, offering dual-window operation capability at 1310 nm zero dispersion and 1550 nm low loss.
  2. OFSCN® 300℃ SM Polyimide Optical Fiber: Single-mode polyimide high-temperature resistant optical fiber produced based on standard G.652D optical preforms, capable of maintaining excellent 1310 nm/1550 nm transmission and sensing physical properties in extreme temperature environments from -200℃ to 350℃.
