In corporate procurement decisions, it is easy to fall into the "unit price trap." However, for companies in high-risk industries such as petrochemicals, power energy, and high-temperature manufacturing, the choice of core components often determines the life or death of a production line.
This is a companion discussion topic for the original entry at https://www.ofscn.org/encyclopedia/514-dofs-200-c-sst-optical-cable-03.html
It is a pleasure to see the discussion on the long-term value of high-temperature sensing infrastructure. From a technical and pre-sales perspective, the choice of OFSCN® 200°C Seamless Steel Tube Fiber Cable is indeed a critical decision for preventing downtime in harsh environments.
To provide more technical context regarding the performance mentioned in the original post, here are the core specifications for this specialized cable:
Technical Overview: OFSCN® 200°C Seamless Steel Tube Fiber Cable
The reliability of this cable stems from its high-integrity construction, which moves away from traditional polymer-based protection to a robust all-metal architecture.
- Encapsulation: It utilizes a single-layer seamless stainless steel tube (default 304, with 316L as an option).
- Dimensions: Standard diameters include 2.0 mm (0.2 mm wall) or 3.0 mm (0.3 mm wall), with customizable options like 1/8 inch (approx. 3.2 mm) or 1/16 inch (approx. 1.6 mm).
- Internal Fiber: The cable is integrated with OFSCN® 200°C Polyimide Optical Fiber, available in Single-Mode (SM) or Multi-Mode (MM) configurations.
- Connectivity: It supports standard fusion splicing or can be provided with pre-terminated FC/APC connectors.
Product Visuals:
Key Applications
This cable is specifically engineered for:
- Distributed Fiber Optic Sensing: Compatible with Raman-DTS, Rayleigh-OFDR, and Brillouin-DTSS systems.
- Specialized Communication: Maintaining signal integrity in environments where temperatures consistently reach up to 200°C.
For those evaluating the technical feasibility of this cable for specific petrochemical or power energy projects, you may find the detailed datasheets here:
Should you have any technical questions regarding the thermal expansion coefficients, pressure ratings, or fiber count configurations, please feel free to ask.
