Can I blow on a dirty patch cord connector to clean it?
Why do experts claim that end-face contamination is the “number one killer” of fiber optic systems?
The assertion that end-face contamination is the “number one killer” of fiber optic systems is rooted in the fundamental physics of light transmission and the microscopic scale of fiber components.
1. The Microscopic Perspective
The core of a standard single-mode fiber is approximately 9 microns in diameter—much smaller than a human hair (approx. 70 microns) or a typical dust particle. Even a microscopic speck of dust, oil from a fingerprint, or residue from “blowing” on the connector can completely block or refract the light signal.
2. Physical Consequences of Contamination
When a contaminated connector is mated, several failure mechanisms occur:
  • Insertion Loss (IL): Contaminants block the light path, causing the signal to weaken.
  • Back Reflection (Return Loss/ORL): Light hits the dirt and reflects back toward the source. In high-power systems or FBG (Fiber Bragg Grating) sensing applications, this can interfere with the laser or destabilize the signal.
  • Permanent Damage (Pitting/Scratching): Fiber connectors use physical contact (PC/APC). When you mate two connectors with trapped dust, the pressure (up to several thousand psi at the contact point) can embed the particle into the glass, causing permanent physical damage that no amount of cleaning can fix.
3. Why “Blowing” is Prohibited
Blowing on a connector with your mouth—a common habit with old electronics—is particularly destructive for fiber optics. Human breath contains:
  • Water vapor (humidity)
  • Microscopic droplets of saliva
  • Oil and biological residue
These create a sticky film on the fiber end-face that actually attracts more dust and causes light to scatter.
Technical Recommendations for OFSCN® Systems
For high-precision systems like OFSCN® Fiber Bragg Grating (FBG) Temperature Sensors or OFSCN® FBG Interrogators, maintaining clean connections is critical for measurement accuracy.
Proper Cleaning Protocol:
  1. Inspect: Use a fiber microscope to check the end-face.
  2. Clean: Use professional dry cleaners (like “one-click” cleaners) or lint-free wipes with 99.9% reagent-grade Isopropyl Alcohol (IPA).
  3. Re-inspect: Ensure the surface is pristine before mating.
To see the standard of equipment used in professional fiber networks, you may refer to our technical documentation:
OFSCN® Fiber Optic Products and Accessories
If you are experiencing signal instability in your FBG system, we recommend checking your connection points first.
