Bridges have been in use for decades. How can fiber optics determine if they can continue to be used?
In civil engineering and Structural Health Monitoring (SHM), assessing old bridges that have been in service for decades cannot rely on single instantaneous data points but rather on a combination of physical measurements, mechanical analysis, and damage mechanics models.
Fiber optic sensing systems (especially Fiber Bragg Gratings, FBGs) do not directly “qualitatively judge” structural lifespan. Instead, they act as the bridge’s “nervous system,” providing core criteria for predicting the remaining service life and evaluating the safety of engineering structures by capturing the evolution of critical mechanical characteristics over the long term.
I. Physical and Mechanical Mechanisms of Fiber Optic Systems in Assessing Old Bridge Condition
1. Dynamic Cyclic Strain Spectrum and Fatigue Cumulative Damage Calculation
Under the repeated alternating effects of vehicle dynamic loads and wind loads, irreversible fatigue micro-cracks will form in high stress concentration areas of steel components, such as welds and the mid-span of main girders.
- Time-History Monitoring: Real-time recording of dynamic strain response curves \varepsilon(t) under vehicle excitation using high-frequency Fiber Bragg Grating demodulators (e.g., with a sampling rate of 100 Hz).
- Rainflow Counting and Miner’s Rule: The continuously changing dynamic strain waveform is decomposed into cycles using the Rainflow-counting Algorithm to extract stress ranges \Delta\sigma_i = E \cdot \Delta\varepsilon_i (where E is the elastic modulus of the component) and corresponding cycle counts n_i for different amplitudes.
- Fatigue Cumulative Damage Assessment: Combining the material’s S\text{-}N curve (Wöhler curve) and using the linear cumulative damage criterion (Palmgren-Miner Rule) to calculate the total damage D:D = \sum_{i} \frac{n_i}{N_i}When D approaches the limit threshold (usually 1.0), it indicates that the fatigue life of the component is nearly exhausted, posing a risk of sudden fracture.
2. Baseline Drift and Plastic Residual Deformation (Residual Strain)
- Within the elastic working limit, the strain returns to zero after unloading.
- If the main load-bearing tension zones of the bridge (e.g., the bottom plate of box girders, lower chord members of steel trusses) experience plastic slip or severe relaxation degradation of prestressed reinforcement under long-term heavy loads, the baseline wavelength of the fiber strain sensor (after removing temperature effects) will exhibit a permanent unidirectional cumulative shift (i.e., residual strain \varepsilon_{\text{res}}). This is a clear signal that the structure has exceeded its elastic working range and its stiffness has degraded.
3. Micro-crack Initiation and Propagation Monitoring (Crack Opening Displacement)
- Fatigue deterioration of concrete bridges often manifests as the initiation and periodic opening/closing of micro-cracks in tension zones.
- Surface-mounted fiber strain gauges or extensometers with large measuring ranges installed across cracks can sense the “breathing” effect of cracks under dynamic loads in real-time. If the residual opening of cracks in a static state continuously widens with age, or if their dynamic closing capability significantly decreases, it indicates that the effective moment of inertia I of the load-bearing cross-section has been damaged.
4. Stiffness Inversion of Structural Dynamic Characteristics (Modal Frequency Degradation)
- The natural vibration circular frequency \omega_n of a bridge, along with the structure’s stiffness E I and mass distribution m, satisfies the physical relationship:\omega_n \propto \sqrt{\frac{E I}{m L^4}}
- As bridges age, the accumulation of internal micro- and meso-scale damage directly leads to a reduction in the overall flexural stiffness E I of the structure. By analyzing the operational modal analysis (OMA) of dynamic environmental excitation using a network of FBG sensors deployed at key cross-sections across the bridge span, the bridge’s fundamental frequency can be identified. If the measured fundamental frequency shows an irreversible downward shift compared to the original design or initial measured data from when the bridge was built (after excluding seasonal stiffness variations caused by temperature), it proves that the overall load-bearing stiffness of the structure has seriously degraded.
5. Calibration Factor Comparison (Load Test Verification)
- Conduct controlled static/dynamic load tests on old bridges that have been in service for decades, applying test vehicles of standard weight.
- Measure the actual strain values \varepsilon_{\text{test}} at key control sections and compare them with the theoretical calculated strains \varepsilon_{\text{calc}} for an undamaged, ideally elastic state to calculate the strain calibration factor \eta :\eta = \frac{\varepsilon_{\text{test}}}{\varepsilon_{\text{calc}}}
- If the calibration factor \eta significantly exceeds the normative limit (usually, codes require \eta < 1), or if the proportion of residual deformation after loading and unloading exceeds the procedural upper limit, it is determined that the bridge can no longer meet the current design load grade.
II. Core Fiber Bragg Grating Sensing Products Involved in Monitoring
In harsh field service environments (large daily temperature variations, humidity, strong electromagnetic interference, long-term service), monitoring the stress, strain, and relative displacement of structural components requires the use of metal-encased specialized fiber optic grating sensors to eliminate sensor creep and zero-point drift.
1. Structural Surface Micro-Strain Monitoring
For steel beam surfaces, near steel structure welds, and flat concrete areas, strain gauges can be directly surface-mounted or spot-welded:
2. Mid-Span Main Girder Long-Gauge Strain and Macro-Deformation Monitoring
For non-uniform stress in concrete structures, cross-joint deformation, or long-gauge average strain measurement, alloy tube-encased strain sensors are often used:
3. Dynamic Demodulation and Signal Acquisition
Used to obtain high-frequency dynamic strain, impact coefficients, and modal frequencies under fast vehicle passage excitation:
III. Summary of Judgment Chain
In engineering practice, determining whether a decades-old bridge “can continue to be used” typically follows this judgment chain:
- Short-term and Instantaneous Condition: Does the measured peak strain under a single extreme load exceed the safety reserve factor of the material’s yield strength?
- Mid-term and Cumulative Condition: Is the measured residual deformation and crack opening rate in a convergent state?
- Long-term and Fatigue Condition: Based on the measured dynamic strain spectrum, has the cumulative fatigue damage D approached the limit? Has the structure’s dynamic characteristic frequency shown an irreversible downward shift in stiffness?
All physical indicators measured by fiber optics must be simultaneously input into the bridge’s finite element model (FEA) for structural capacity re-calculation, ultimately forming engineering decisions for reinforcement, restricted load traffic, or decommissioning.
