What is "structural health monitoring (SHM)" selection?
Why is fiber optic sensing considered the “nervous system” for large-scale infrastructure?
In Structural Health Monitoring (SHM) of large-scale infrastructure, likening fiber optic sensing systems to the “nervous system” of buildings and engineering structures is not merely a figurative biomimetic rhetoric but is grounded in profound principles of physics, materials science, and information engineering.
The core characteristics of a biological nervous system include: minimally invasive/in-situ distributed sensory terminals, integrated sensing and signal transmission pathways, physiological conduction resistant to external environmental interference, and real-time feedback on subtle internal states (stress, temperature, damage). Fiber optic sensing technology perfectly replicates these characteristics in engineering structures:
I. “Integrated Sensing and Transmission” Physical Architecture and Minimal Wiring Topology
In traditional electrical monitoring systems (such as resistance strain gauges, vibrating wire sensors):
  • Each measurement point requires a dedicated lead wire. In large-scale structures (like long-span bridges, dams, ultra-long tunnels), hundreds or thousands of measurement points would result in tens of thousands of intertwined copper cables. The weight of the wiring, the bulk of its routing, and complex connectors can easily become weak links in the system’s failure.
In fiber optic sensing systems:
  • A single silica (\text{SiO}_2) quartz optical fiber serves as both the sensing medium and an ultra-high-speed, low-loss signal transmission channel.
  • Utilizing Wavelength Division Multiplexing (WDM) and Time Division Multiplexing (TDM) technologies, dozens to hundreds of Fiber Bragg Grating (FBG) measurement points can be daisy-chained on a single fiber, forming a quasi-distributed sensing array; alternatively, optical backscattering (Rayleigh, Raman, Brillouin scattering) can achieve millimeter-level continuous sampling over tens of kilometers in a fully distributed manner (DAS / DTS / BOTDA).
  • This architecture, where a single fiber core connects multiple points, closely aligns with the biological topology of nerve fibers (axons) transmitting sensory signals.
II. Minimal Geometric Size and “In-situ Non-destructive Integration” with the Structural Matrix
The standard cladding diameter of conventional single-mode communication optical fibers is only 125\ \mu\text{m} (ultra-thin fibers can have cladding outer diameters as small as 60\ \mu\text{m} \sim 80\ \mu\text{m} ), with the coated outer diameter typically ranging from 150\ \mu\text{m} \sim 250\ \mu\text{m}.
  • Minimally Invasive/Non-destructive Embedding: Such fine geometric dimensions allow it to be directly cast within concrete components, embedded in prestressed steel strand bundles, sandwiched within composite laminates, or laid in micro-grooves on the surface of metal structures, much like nerve fibers.
  • No Stress Concentration Defects: Compared to bulky traditional mechanical/electrical sensors, the slender optical fiber does not compromise the mechanical continuity of the base matrix material, nor does it induce local cracks or stress concentrations, enabling in-situ sensing of deep internal stresses, strains, and temperatures within the material.
III. Intrinsic Safety and Superior Durability Throughout the Lifecycle
The design service life of large-scale infrastructure typically spans 50 to over 100 years, requiring monitoring systems to possess comparable longevity and ultra-high reliability:
  1. Absolute Electrical Insulation and Lightning Resistance: Silica is a highly insulating dielectric, and optical signal transmission is immune to interference from high-voltage power grids, electrified railways, high electromagnetic pulses (EMI), and lightning strikes.
  2. Chemical Inertness and Corrosion Resistance: In humid, salt-laden marine environments, strong acidic or alkaline underground conditions, or flammable/explosive scenarios (such as underground utility tunnels or petrochemical storage tanks), quartz optical fibers exhibit excellent chemical stability, completely eliminating the risks of electric sparks and electrochemical corrosion short circuits.
  3. Zero-Drift Absolute Measurement Mechanism: Taking Fiber Bragg Gratings (FBGs) as an example, their sensing mechanism is based on the absolute shift of the Bragg reflection wavelength \lambda_B :
    (where n_{\text{eff}} is the effective refractive index and \Lambda is the grating period). Wavelength is an absolute spectral physical quantity, unaffected by light source power fluctuations, fiber bending losses, or connector insertion loss aging, thus offering excellent long-term zero-point stability.
IV. Multimodal “Proprioception” and Real-time Dynamic Response
A healthy biological organism relies on its nervous system to perceive touch, temperature, tension, and balance; similarly, infrastructure needs to comprehensively sense environmental loads and structural responses:
  • Multi-physical Quantity Demodulation: Fiber optic strain and temperature exhibit a linear wavelength shift relationship:
    \frac{\Delta \lambda_B}{\lambda_B} = (1 - p_e)\varepsilon + (\alpha + \xi)\Delta T
    (where p_e is the effective photoelastic coefficient, \alpha is the coefficient of thermal expansion, and \xi is the thermo-optic coefficient). With appropriate packaging design, micro-strain ( \mu\varepsilon ), temperature ( ^\circ\text{C} ), pressure, inclination, acceleration vibration, and even three-dimensional shape changes can be accurately demodulated separately.
  • Fast Dynamic Response: Coupled with high-frequency fiber optic interrogators (sampling rates up to kHz to tens of kHz), fiber optic networks can not only monitor slow static processes like foundation settlement and concrete creep but also capture high-frequency dynamic impact waveforms caused by seismic loads, wind loads, and train/heavy vehicle passage over bridges.
V. Typical Engineering Application Components
In harsh civil engineering environments, bare optical fibers must undergo special protective encapsulation to balance the conflict between “high-fidelity strain transfer” and “resistance to construction shear damage”:
  • For monitoring prestressed tendons, concrete cracks, and surface strain, high-modulus micro-protective structures are often used, such as Fiber Bragg Grating sensors encapsulated in polymer or stainless steel capillaries: OFSCN® Polymer-encapsulated Fiber Bragg Grating Strain Sensor (0.7mm/1.2mm diameter). These sensors can provide high linear responses from hundreds of micro-strains to thousands of micro-strains within a very small cross-section, making them suitable for direct embedding within the structure as “sensory neurons.”
Conclusion
Fiber optic sensing systems deeply integrate sensing elements with transmission media. Their physical characteristics—high integration, electromagnetic interference immunity, intrinsic safety, minimally invasive embedding, and ultra-long service life—enable the construction of a network resembling biological neurons and axons within cold, rigid steel-reinforced concrete structures. This network grants these structures the ability to perceive their own strain evolution, fatigue damage, and environmental disturbances, thus rightfully earning them the designation of the “nervous system” for large-scale infrastructure.
