cmh
Last Updated: 20 January 2026
In the energy industry and aerospace research, ultra-low temperature environments below -150℃ present a massive challenge to all monitoring equipment. Specifically, in Liquefied Natural Gas (LNG) transport, liquid hydrogen energy systems, and cryogenic fuel tank testing for spacecraft, conventional materials often fail due to low-temperature embrittlement.
This is a companion discussion topic for the original entry at https://www.ofscn.org/encyclopedia/524-sst-cables-two-layer-03.html
Regarding the challenges of monitoring in ultra-low temperature environments such as LNG storage and aerospace testing, the material selection for fiber optic protection is critical. When temperatures drop below -150°C, conventional polymer-based fiber coatings and cable jackets become brittle and lose their mechanical integrity.
For these cryogenic applications, the OFSCN® Double-Layer High-Temperature Downhole Fiber Optic Cable (which is also rated for extreme low temperatures) provides a robust solution.
Technical Analysis for Cryogenic Applications:
- Material Stability: By utilizing 316L stainless steel or 825 alloy seamless tubes, the cable avoids the embrittlement issues associated with plastics. These metals maintain excellent ductility and structural integrity at -200°C.
- Double-Layer Protection: The nested dual-tube design provides redundant protection against high pressure and mechanical stress, which is vital in downhole or high-pressure fuel tank environments.
- Fiber Selection: For extreme cold, polyimide-coated or gold-coated fibers are typically used within these tubes to ensure the optical signal remains stable despite the thermal contraction of the surrounding structure.
Recommended Product:
Standard Product Image:
To better understand your specific application requirements, could you please clarify the following:
- What is the specific minimum operating temperature and pressure the cable will be exposed to?
- Will the cable be used for distributed sensing (e.g., DTS/DAS) or for point-sensing using FBGs?
