Coefficient of Thermal Expansion (CTE) Matching in Packaging
What happens during heating if the CTE difference between the steel tube and the optical fiber is too large?
If the Coefficient of Thermal Expansion (CTE) difference between the steel tube and the optical fiber is too large during heating, several critical issues can arise, primarily affecting the performance and longevity of the fiber optic sensor or cable:
  1. Strain on the Optical Fiber: As the temperature increases, the steel tube and the optical fiber will expand at different rates. If the steel tube has a significantly higher CTE than the fiber, it will expand more, putting the optical fiber under tensile strain. Conversely, if the fiber has a higher CTE (which is less common in this specific material pairing), it would be compressed. Excessive strain can lead to:
    • Fiber Damage/Breakage: Beyond the elastic limit, the fiber can suffer microscopic damage or even macroscopic breakage, especially if it’s subjected to repeated thermal cycling.
    • Signal Loss: Strain on the fiber can induce micro-bends or macro-bends, leading to increased optical attenuation and signal loss.
    • Measurement Errors (for Sensors): In Fiber Bragg Grating (FBG) sensors, strain directly influences the Bragg wavelength. An uncontrolled and inconsistent strain induced by CTE mismatch will introduce significant errors in temperature or strain measurements, making the sensor unreliable.
  2. Encapsulation Delamination/Failure: The differential expansion can stress the interface between the fiber and the inner surface of the tube. This can lead to the delamination of any internal coatings or bonding materials, or even physical damage to the tube itself if the forces are substantial enough and the tube material is not ductile.
  3. Hysteresis and Drift: Due to friction and plastic deformation, the strain induced by the CTE mismatch may not be fully reversible upon cooling, leading to hysteresis in sensor readings and long-term drift in calibration.
To mitigate these issues, OFSCN utilizes specialized packaging techniques and materials, such as our metal alloy tube encapsulated sensors, designed to minimize the effects of CTE mismatch in high-temperature environments.
For applications requiring robust performance in challenging temperature conditions, you may find the following product relevant:
It is designed with materials and structures to ensure stable operation over wide temperature ranges.
Product images:
