Difference between Fiber Bragg Grating Sensors and Distributed Optical Fiber Sensors – Environmental Differences and how to Choose - DCYS - ofscn.net
This article introduces the different environments of distributed optical fiber sensors and fiber Bragg grating sensors from multiple perspectives, and briefly compares the advantages and disadvantages of fiber Bragg grating sensing technology and distributed optical fiber sensing technology based on Raman scattering, Rayleigh scattering, and Brillouin scattering. Understanding these differences is important to choose the appropriate fiber sensing technology, and select OFSCN's corresponding series of fiber Bragg grating sensors or distributed optical fiber sensors.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-baike/294-application-difference
Welcome to the OFSCN technical forum.
This is a professional discussion space for optical fiber sensing technologies. The topic introduced by @blueman highlights the fundamental differences between Fiber Bragg Grating (FBG) sensors and Distributed Optical Fiber Sensors (DOFS), such as those based on Raman (DTS), Brillouin (DTSS), or Rayleigh (DAS) scattering.
From a technical perspective, choosing between these two technologies often depends on your specific engineering requirements:
1. Fiber Bragg Grating (FBG) Sensors
FBG technology is ideal for point sensing where high precision, high frequency, and specific location monitoring are required.
  • Key Advantage: It allows for “Quasi-Distributed” sensing by multiplexing multiple FBGs on a single fiber.
  • Best Use Case: Monitoring specific stress points on structures, high-accuracy temperature measurements in small areas, or high-speed vibration analysis.
  • Relevant Products:
2. Distributed Optical Fiber Sensors (DOFS)
DOFS technology treats the entire length of the optical fiber as a sensor, providing a continuous profile of temperature or strain.
  • Key Advantage: No “blind spots” along the fiber line. It is highly effective for long-distance monitoring.
  • Best Use Case: Fire detection in long tunnels, leak detection in pipelines, or structural health monitoring of large dams and power cables.
Technical Guidance for Selection
To determine which technology fits your project, we recommend evaluating the following:
  1. Measurement Range: Do you need to monitor a few specific points (FBG) or several kilometers of distance (DOFS)?
  2. Sampling Frequency: Does your application require high-speed dynamic response (FBG can reach kHz ranges)?
  3. Physical Environment: Is the installation environment subject to extreme temperatures or high mechanical stress?
If you have a specific application scenario, please describe your environmental conditions and measurement goals, and I can provide a more detailed technical diagnosis.
