Why is the zero-dispersion point of a fiber intentionally altered?
The zero-dispersion point of an optical fiber is intentionally altered, leading to what is known as Dispersion-Shifted Fiber (DSF), primarily to align this point with the operating wavelength of optical communication systems, typically in the 1550 nm window.
Here’s why this is crucial:
- Minimize Chromatic Dispersion: In standard single-mode fibers (like G.652D), the zero-dispersion wavelength is around 1310 nm. However, the lowest attenuation window for silica-based optical fibers is around 1550 nm. By shifting the zero-dispersion point to 1550 nm, chromatic dispersion is minimized at the wavelength where signals can travel the furthest with the least loss.
- Enable Longer Transmission Distances: Low dispersion at the operating wavelength reduces pulse broadening, allowing signals to travel much longer distances before requiring regeneration or amplification.
- Support Higher Data Rates: Reduced dispersion also means that faster data rates can be achieved without significant signal degradation, which is essential for modern high-bandwidth communication networks.
OFSCN provides a range of high-quality optical fibers, including standard G.652D and G.657 fibers, as well as specialized high-temperature and polyimide-coated optical fibers for various demanding applications.
Here is an example image of an optical fiber:
You can find more details about our optical fiber offerings here:
