cmh
Last Updated: 19 October 2025
In extreme environment projects (such as downhole oil and gas exploration, large industrial furnace monitoring, or remote scientific research facilities), the length and structure of fiber optic patch cords are often unique to the application. A standard 5 meter or 10 meter patch cord simply cannot meet complex cabling requirements.
This is a companion discussion topic for the original entry at https://www.ofscn.org/encyclopedia/466-patch-cords-03.html
It is indeed a significant challenge in industrial and scientific applications where standard lengths are insufficient. In environments such as downhole exploration or high-temperature furnace monitoring, the physical protection and the exact length of the fiber optic patch cord are critical for system reliability.
At Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN), we specialize in addressing these requirements through our customization services. Depending on your specific environmental constraints, we offer several specialized solutions:
1. High-Temperature Resistance
For projects involving extreme heat, standard PVC or LSZH jackets will fail. We provide patch cords utilizing stainless steel seamless tube encapsulation:
2. High Mechanical Strength
For deployments requiring high tensile strength or crush resistance (like long-distance cabling in harsh terrains), we offer:
Standard Product Visuals:
Customization Capabilities:
- Length: From 1 meter to several kilometers.
- Connectors: FC, ST, LC, SC (PC or APC polishing).
- Fiber Types: Single-mode (G.652D/G.657), Multi-mode, or Polarization Maintaining (PM) fibers.
If you are designing a system for a specific extreme environment, could you please specify the peak operating temperature and the required mechanical tension for your cabling? This information will help in determining the most suitable encapsulation structure.
