Product Functions: Single-point/multi-point temperature detection under electrification,temperature compensation for strain and stress sensors.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/fbgs-low-voltage.html
Regarding the OFSCN® 150℃ Low-Voltage Insulated Fiber Bragg Grating Temperature Sensor mentioned in this topic, it is specifically designed for environments where electrical insulation and temperature monitoring are both required.
Technical Overview
This sensor utilizes a hybrid packaging technology: a high-polymer insulating material combined with a seamless stainless steel tube nesting. This construction ensures that the sensor maintains its insulation properties under specific voltage conditions while remaining robust enough for industrial applications.
Key Specifications:
- Temperature Range: -40°C to +150°C.
- Standard Diameter: 1.0 mm (customizable).
- Standard Length: 20 cm (customizable from 10 cm to several meters).
- Connector Type: Default FC/APC (ST, LC, SC, and PC types are available upon request).
- Applications: Single-point or multi-point temperature detection in electrified environments and temperature compensation for FBG strain/stress sensors.
Visual Reference
Related Documentation
For detailed technical parameters and customization options, you can visit the official product page:
If you have specific requirements regarding the insulation voltage levels or the number of sensing points required for your project, please feel free to provide those technical details.
