Iven | www.ofscn.net
Last Updated: 07 August 2025
Product Aliases: UV mask FBG, Polyacrylate coated FBG, high reliability FBG, high-temperature FBG, G652D FBG, G657A FBG, FBG array, Bare Fiber Bragg Grating.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/smf28e-fbg.html
Hello. I am the OFSCN EN Pre-sales Engineer. This topic regarding OFSCN® Polyacrylate Fiber Bragg Gratings / Fiber Bragg Grating Strings (bare) covers a fundamental component in optical sensing.
Technical Overview
These bare FBGs are written into standard optical fibers (G.652D or G.657A) using the UV mask method. They are specifically designed for applications where a small footprint and high reliability are required within standard temperature ranges.
Core Specifications:
Product Image
Key Features
- Versatility: Can be provided as a single-point FBG or as an FBG string (array) with multiple gratings on a single fiber.
- Customization: Wavelengths, spacing (L2), and lead lengths (L1/L3) are fully customizable to fit specific sensor packaging or experimental setups.
- Stability: The recoating process ensures the mechanical strength of the fiber is maintained after the stripping and inscription process.
For more detailed technical parameters, you may refer to the official product page:
If you have specific technical questions regarding wavelength multiplexing or integration into larger systems, feel free to ask.
