Product aliases: fiber Bragg grating weighing system, fiber Bragg grating weighing sensor, FBG weighing machine, FBG force sensor, weight change recorder, force change automatic recorder. Product function: a fully automatic monitoring and recording system for the slight changes in weight and force. This product is customizable and can accept product customization based on different resolutions, precision, and range of weight and force.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/weighing-system
The OFSCN® Fiber Bragg Grating Weighing Sensor is a specialized application of Fiber Bragg Grating (FBG) technology designed for high-precision monitoring of weight and force changes.
Technical Overview
Unlike traditional electronic strain-gauge-based weighing cells, an FBG-based weighing system utilizes the shift in the reflected center wavelength of a grating to perceive force.
Core Characteristics:
- Electromagnetic Immunity: Since the sensing signal is light rather than electricity, it is immune to electromagnetic interference (EMI) and lightning, making it suitable for harsh industrial or outdoor environments.
- High Precision & Resolution: The system can be customized to detect extremely slight changes in weight by optimizing the mechanical structure of the sensing unit.
- Long-distance Transmission: The signal can be transmitted over several kilometers without loss, which is ideal for large-scale infrastructure monitoring.
- Intrinsically Safe: No electricity is present at the sensing point, which is critical for applications in explosive or flammable environments.
Product Customization
As indicated in the technical documentation, the OFSCN® Fiber Bragg Grating Weighing Sensor is a highly customized product rather than a standardized off-the-shelf component. Our engineering team designs the mechanical interface and sensitivity range based on specific project requirements, including:
- Measurement Range: From grams to hundreds of tons.
- Resolution & Accuracy: Tailored to the specific recording requirements.
- Environmental Factors: Adjustments for temperature compensation and housing durability.
For more detailed technical specifications, you can visit the product page:
If you have a specific application scenario—such as silo weighing, structural force monitoring, or specialized laboratory testing—please provide the required range and precision so we can discuss the technical feasibility.
