Product aliases: fiber Bragg grating weighing system, fiber Bragg grating weighing sensor, FBG weighing machine, FBG force sensor, weight change recorder, force change automatic recorder. Product function: a fully automatic monitoring and recording system for the slight changes in weight and force. This product is customizable and can accept product customization based on different resolutions, precision, and range of weight and force.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-products/weighing-system.html
The OFSCN® Fiber Bragg Grating Weighing System (including FBG weighing sensors and force sensors) is a highly specialized solution designed for monitoring slight changes in weight and force with high precision. Unlike traditional electronic sensors, these FBG-based systems are immune to electromagnetic interference (EMI) and are suitable for long-term monitoring in harsh environments.
Based on the technical profile of this product, please note the following key characteristics:
- High Customization: As these systems are often integrated into specific mechanical structures, they are not off-the-shelf standard products. Each system is customized based on your required resolution, measurement range, and accuracy.
- Multi-Directional Capability: For applications requiring complex force analysis, we also offer the OFSCN® Fiber Bragg Grating 3D Force Sensor, which can measure multi-directional forces.
- Principle of Operation: These sensors typically utilize the strain-wavelength relationship. For certain weighing applications, the OFSCN® Fiber Bragg Grating Displacement Sensor or strain-based sensors are used as the core sensing element.
Consultative Diagnosis
To provide a technical recommendation or to evaluate the feasibility of your weighing/force monitoring project, could you please clarify the following technical details?
- Measurement Range and Environment: What is the maximum weight or force (in kg or N) you need to measure, and what is the operating temperature of the environment?
- Installation Constraints: Are you looking for a standalone weighing platform, or do you need to integrate FBG sensing elements into an existing structure (such as a bridge, tank, or medical device)?
For more detailed technical parameters, you may refer to the product page:
