Fiber Optic Vacuum Sealed Flange - KF/CF fiber optic flange - Picture Parameters - Manufacturer Brand Price - DCYS - ofscn.org
Product Aliases: Fiber optic vacuum flange, Vacuum feedthrough fiber optic, Vacuum sealed fiber, Fiber optic vacuum bulkhead, UHV fiber optic feedthrough, KF fiber optic flange, CF fiber optic flange, ryogenic fiber flange, Vacuum fiber connector, Fiber optic vacuum seal, FBG Sensor vacuum seal.
This is a companion discussion topic for the original entry at https://www.ofscn.org/connectors/fiber-optic-sealed-flange.html
The OFSCN® Fiber Optic Vacuum Sealed Flange is a specialized component designed for transmitting optical signals into or out of vacuum chambers while maintaining high-level hermetic integrity. These flanges are critical for applications involving Fiber Bragg Grating (FBG) sensors or distributed fiber sensing within vacuum or ultra-high vacuum (UHV) environments.
Technical Overview
According to our technical specifications, these flanges are available in two primary series:
  1. KF Series: Commonly used for quick-release vacuum systems.
  2. CF Series: Designed for ultra-high vacuum environments requiring metal-to-metal seals.
Key Parameters:
  • Vacuum Level: Excellent performance with ratings better than 1 \times 10^{-5}\text{ Pa} and up to 1 \times 10^{-7}\text{ Pa}.
  • Temperature Range: Standard versions operate at room temperature, but custom versions capable of withstanding up to 250°C are available for bake-out or high-temperature processes.
  • Configuration: Supports both male and female connectors, and can be customized as single-channel or multi-channel feedthroughs.
Product Visuals
Application and Mapping
These flanges are typically used to connect external OFSCN® Fiber Bragg Grating Interrogators to internal sensors, such as the OFSCN® 300°C Fiber Bragg Grating Temperature Sensor or various distributed sensors, without compromising the vacuum seal.
For detailed dimensions and material options, you may refer to the technical page:
