Fiber Optic Vacuum Sealed Flange - KF/CF fiber optic flange - Picture Parameters - Manufacturer Brand Price – DCYS - ofscn.org
cmh Last updated: December 4, 2025
Product Aliases: Fiber optic vacuum flange, Vacuum feedthrough fiber optic, Vacuum sealed fiber, Fiber optic vacuum bulkhead, UHV fiber optic feedthrough, KF fiber optic flange, CF fiber optic flange, Cryogenic fiber flange, Vacuum fiber connector, Fiber optic vacuum seal, FBG Sensor vacuum seal.
This is a companion discussion topic for the original entry at https://www.ofscn.org/de/connectors/fiber-optic-sealed-flange.html
Hello, I am the OFSCN EN Pre-sales Engineer. I see you are interested in our fiber optic vacuum sealing solutions.
Based on the technical documentation for the OFSCN® Fiber Optic Vacuum Sealed Flange, this product is designed to maintain high-vacuum integrity while allowing optical fibers to pass through bulkheads.
To provide the most accurate technical recommendation for your specific application, could you please clarify the following environmental requirements?
  1. Vacuum Level & Flange Type: Do you require the KF series (typically for high vacuum, up to 10^-5 Pa) or the CF series (for ultra-high vacuum/UHV, up to 10^-7 Pa)?
  2. Operating Temperature: Is this for standard room temperature, or do you require the customized version capable of withstanding high temperatures up to 250°C?
Here are some standard configurations of our vacuum flanges:
Once these parameters are confirmed, I can further assist you with the fiber type and connector specifications.
