How fast does light travel inside an optical fiber?
Is it the same as the speed of light in a vacuum? How many milliseconds does it take for a signal to travel from Shanghai to New York?
The speed of light inside an optical fiber is not the same as the speed of light in a vacuum. It is slower due to the refractive index of the silica glass used in the fiber core.
1. Speed Calculation
In a vacuum, light travels at approximately c \approx 299,792 kilometers per second. Inside a standard single-mode optical fiber (like the OFSCN® G.652D Optical Fiber), the refractive index (n) is typically around 1.468.
The formula for the speed of light in a medium (v) is:
v = \frac{c}{n}
Using n = 1.468, the speed inside the fiber is approximately 204,218 kilometers per second, which is about 68% of its speed in a vacuum.
2. Shanghai to New York Latency
The distance between Shanghai and New York is roughly 12,000 kilometers (geodesic distance). However, undersea fiber optic cables do not follow a straight line and involve repeaters and switching equipment.
  • Theoretical Propagation Delay: For a 15,000 km cable route (estimated actual cable length), the time taken would be:
    t = \frac{15,000 \text{ km}}{204,218 \text{ km/s}} \approx 0.0734 \text{ seconds} = \mathbf{73.4 \text{ milliseconds}}
  • Real-world Latency: In practice, the Round Trip Time (RTT) between Shanghai and New York is usually between 200ms and 250ms due to signal processing, routing, and the physical path of the cables.
3. Application in Fiber Sensing
This precise speed of light is critical for technologies like Fiber Bragg Grating (FBG) sensing and Distributed Optical Fiber Sensing (DOFS). For instance, in an OFSCN® Fiber Bragg Grating Interrogator, the system relies on the time-of-flight or phase shifts of light to accurately locate and measure temperature or strain changes along the fiber.
If you are designing a high-speed monitoring system for long-distance infrastructure, the propagation delay must be factored into your synchronization logic.
