In the face of salt spray corrosion and heavy object impact, which encapsulation structure is the most reliable?
Under harsh and severe operating conditions such as offshore oil drilling platforms, the two core failure mechanisms for jumpers are: high-concentration salt fog and seawater aerosol erosion (inducing stress corrosion and electrochemical corrosion), and severe mechanical impacts and radial squeezing caused by the drop, stepping on, and dragging of heavy machinery.
For such demanding applications, the most reliable jumper encapsulation form is: a three-layer composite armored structure of ‘PE external polyethylene anti-corrosion sheath + stainless steel wire stranded rope + inner stainless steel seamless steel pipe’.
I. Analysis of Structural Anti-Destruction Physical Mechanisms
- Inner Layer Micro Stainless Steel Seamless Steel Pipe (Core Barrier):
- The interior is composed of a small-caliber stainless steel seamless steel pipe, forming a rigid protective cavity, where optical fibers are in a state of no stress or micro-stress within the pipe.
- When external point contact impact or radial squeezing occurs, the cylindrical metal pipe shell effectively resists lateral pressure through hoop bending stress, isolating external forces outside the pipe wall and completely preventing increased optical loss or brittle fracture caused by micro-bending distortion of the silica core.
- Middle Layer Stainless Steel Wire Stranded Layer (Tensile Strength and Impact Absorption):
- The middle layer uses multiple strands of stainless steel wire densely twisted in a spiral pattern (similar to a micro-wire rope configuration).
- This structure can disperse and absorb transient impact kinetic energy through micro-sliding and elastic deformation between the steel wires when subjected to heavy object impact; it simultaneously provides extremely high axial tensile stiffness and strength to resist dragging and pulling.
- Outer Layer PE (Polyethylene) Anti-corrosion and Wear-Resistant Sheath (Salt Fog and Medium Isolation):
- The high-saline fog environment at sea contains a large amount of free-penetrating Cl- ions. Ordinary metal or galvanized layers are prone to chemical oxidation or pitting corrosion if directly exposed.
- PE material has extremely low water absorption, excellent resistance to chemical medium penetration, and weather resistance, preventing seawater, salt fog, and drilling mud from contacting the internal load-bearing metal, and is also abrasion-resistant and scratch-resistant.
II. Matching Official Specification Product: OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord
Based on the above physical protection requirements, Beijing Dacheng Yongsheng Technology Co., Ltd. recommends using the OFSCN® 3.0mm Steel Wire Rope Fiber Optic Patch Cord. This model is specifically designed for heavy mechanical loads and corrosive environments.
1. Structure and Key Technical Indicators
- Encapsulation Structure: Fiber connector (FC, ST, etc.; PC or APC acceptable) + outer PE sheath + 0.45mm stainless steel wire stranded rope + 0.9mm stainless steel seamless steel pipe + optical fiber.
- Default Outer Diameter: 3.0mm.
- Tensile Strength: > 1200N.
- Compressive Strength: > 200MPa.
- Default Fiber Core: OFSCN® G.657 Optical Fiber (with excellent bending loss margin, further reducing the risk of extreme deformation).
- Operating Temperature Range: -40°C to +75°C.
2. Standard Product Images
III. Comparison with Other Models and Selection Considerations
- Comparison with All-Metal Exposed Structure: The OFSCN® 2.0mm Steel Wire Rope Fiber Optic Patch Cord also possesses high tensile (> 1500N) and high compressive (> 150MPa) strength, but its outer layer is exposed galvanized steel wire stranding. Its anti-corrosion lifespan is inferior to the 3.0mm structure with a PE outer sheath when directly immersed in heavy, high-humidity salt fog for extended periods.
- Connector Selection Recommendation: In environments with significant vibration on offshore platforms, it is recommended to use FC/APC connectors with threaded locking mechanisms or ST/APC connectors with bayonet locking to prevent end-face disengagement due to mechanical vibration or accidental bumps.
More jumper product specifications can be found at: OFSCN® Fiber Optic Patch Cord Product Classification Link .
