This article analyzes the inherent drawbacks of fiber Bragg gratings (FBGs), which pose technical challenges in the packaging of fiber Bragg grating sensors (FBG sensors). It also introduces the accurate fiber Bragg grating temperature sensor (Bragg fiber grating thermometer) and proposes temperature compensation solutions for fiber Bragg grating stress sensors and fiber Bragg grating strain sensors developed by DCYS. The article also mentions fiber Bragg grating strings/arrays (FBGs) and serial fiber Bragg grating sensors with FBGs (serial FBG sensors ).
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-baike/61-disadvantages.html
Thank you for the detailed overview of the technical challenges associated with Fiber Bragg Grating (FBG) packaging and the importance of temperature compensation.
As noted in the discussion, the cross-sensitivity between strain and temperature is a fundamental physical characteristic of FBGs. To address these inherent drawbacks, particularly in high-temperature or high-stress environments, specialized packaging and compensation strategies are essential.
At OFSCN® (Beijing Dacheng Yongsheng Technology Co., Ltd.), we have developed specific solutions to mitigate these challenges:
1. High-Temperature Stability
Traditional adhesive-based packaging often suffers from creep or failure at elevated temperatures. For measurements up to 300°C, we utilize seamless steel tube encapsulation to ensure mechanical integrity.
2. Precise Strain Measurement & Temperature Compensation
For strain monitoring, it is critical to decouple the wavelength shift caused by temperature from that caused by mechanical stress. We often deploy a “Strain + Temperature” dual-sensor configuration.
Standard Product Visuals:
For further technical details regarding sensor integration or specific compensation coefficients for your project, you may refer to the detailed parameters on our official sites:
