Iven | www.ofscn.net
Last Updated: 09 September 2023
This article introduces the temperature compensation methods and principles for FBG stress sensors and answers the question, "Is FBG stress measurement sensitive to temperature?" It also highlights the accuracy of OFSCN® Capillary Seamless Steel Tube Fiber Bragg Grating Temperature Sensors, which can be used for temperature compensation in FBG stress sensors and other types of FBG sensors. Additionally, it provides the temperature compensation scheme offered by DCYS.
This is a companion discussion topic for the original entry at https://www.ofscn.net/fbg-baike/102-temperature-compensation-02.html
The article provided by blueman highlights a critical aspect of fiber optic sensing: Temperature Sensitivity. In Fiber Bragg Grating (FBG) technology, the reflected wavelength shifts in response to both mechanical strain (stress) and thermal changes. To obtain an accurate stress measurement, the thermal component must be decoupled.
Technical Principle of Temperature Compensation
For any FBG-based sensor, the wavelength shift (\Delta\lambda) is defined by:
\Delta\lambda = \Delta\lambda_{\epsilon} + \Delta\lambda_{T}
Where:
- \Delta\lambda_{\epsilon} is the shift caused by mechanical strain/stress.
- \Delta\lambda_{T} is the shift caused by temperature changes.
To isolate the stress data, a second FBG sensor—the Temperature Compensation Sensor—is placed in the same thermal environment but remains mechanically isolated from the stress being measured. By subtracting the wavelength shift of the temperature sensor from the total shift of the stress sensor, we achieve precise “Temperature Compensation.”
Recommended Products for Stress and Temperature Sensing
Based on the OFSCN® technical standards, the following products are typically used in tandem for high-precision engineering applications:
For Stress Measurement:
OFSCN® Fiber Bragg Grating Stress Sensor
This sensor is frequently based on the OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor. It utilizes a seamless steel tube design to ensure excellent linearity and durability.
For Temperature Compensation:
OFSCN® 100°C Fiber Bragg Grating Temperature Sensor
Specifically designed for thermal monitoring, this sensor provides the reference data needed to nullify the thermal effects on the stress sensor.
Why Use OFSCN® Seamless Steel Tube Packaging?
- Zero Creep: Unlike traditional sensors using adhesive-based packaging, the seamless steel tube prevents measurement errors caused by glue aging or slippage.
- High Sensitivity: The capillary design ensures that the internal FBG responds rapidly to both temperature and mechanical changes.
- Scalability: Multiple sensors can be integrated into a single fiber string to monitor stress and temperature at various points simultaneously.
For more detailed technical specifications on how to implement these compensation schemes in your specific project, you can explore the product links above.
