Macro-bending vs. Micro-bending
How do they differ in spectral behavior and loss mechanisms?
Macro-bending and micro-bending are two distinct phenomena in optical fibers that lead to signal loss and can affect the spectral characteristics of light propagating through them.
Macro-bending
  • Description: Macro-bending refers to relatively large-radius curves in an optical fiber, typically visible to the naked eye. These bends occur when the fiber is routed around corners or spooled too tightly.
  • Spectral Behavior: When an optical fiber is macro-bent, the light propagating in the fiber core encounters a point where its speed (due to the refractive index of the core) is insufficient to maintain total internal reflection at the cladding interface on the outer side of the bend. This causes light to radiate out of the fiber. The spectral impact is a general increase in attenuation across a broad wavelength range, with shorter wavelengths often experiencing less loss than longer wavelengths, as they are more tightly confined.
  • Loss Mechanisms: The primary loss mechanism is radiative loss, where the evanescent field of the guided mode extends beyond the critical angle at the outer bend, causing light to leak out of the fiber. This loss is highly dependent on the bending radius and the numerical aperture of the fiber.
Micro-bending
  • Description: Micro-bending refers to microscopic, localized, and random variations or distortions along the fiber axis, usually caused by external forces like uneven pressure, imperfect cabling, or manufacturing defects. These are typically too small to be seen without magnification.
  • Spectral Behavior: Micro-bending causes coupling between guided modes and higher-order radiation modes or cladding modes. This leads to a broader and more complex spectral attenuation, as different modes are affected differently. The losses tend to be wavelength-dependent, often showing higher loss at longer wavelengths. In Fiber Bragg Gratings (FBGs), micro-bends can induce non-uniform strain along the grating, leading to broadening or distortion of the FBG’s reflection spectrum.
  • Loss Mechanisms: The main loss mechanism is mode coupling. The micro-bends periodically perturb the fiber’s refractive index profile, causing guided light to couple into radiation modes or cladding modes, which then dissipate. This effect is particularly pronounced when the spatial period of the micro-bends matches the beat length between a guided mode and a radiation mode.
Key Differences Summarized:
  • Scale: Macro-bends are large, visible curves; micro-bends are microscopic, localized distortions.
  • Cause: Macro-bends are from large-scale routing/installation; micro-bends are from localized pressure or imperfections.
  • Loss Mechanism: Macro-bends primarily cause radiative loss; micro-bends primarily cause mode coupling.
  • Spectral Impact: Macro-bends cause general attenuation (often worse at longer wavelengths); micro-bends cause more complex, often wavelength-dependent attenuation and can distort FBG spectra.
For applications requiring bend-insensitive performance, such as in tight spaces or scenarios prone to micro-bending, specific fiber types like the OFSCN® G.657 Optical Fiber are designed to minimize these losses.
