What is "polarization-dependent loss (PDL)"?
Why does the signal strength experience slight jitter when the jumper cable is shaken?
In optical metrology and fiber optic sensing testing, the slight jitter in the detected signal strength (optical power) caused by shaking a standard single-mode fiber patch cord is an extremely typical and common optical phenomenon. The fundamental physical mechanism is primarily caused by the interaction between fiber polarization state evolution and the Polarization-Dependent Loss (PDL) of devices in the system, possibly accompanied by minor geometric bending loss modulation.
1. Core Mechanism: Coupling of Polarization State (SOP) Evolution and PDL
(1) Shaking Induces Random Drift of Polarization State (SOP)
Standard single-mode fibers (e.g., nominally isotropic standard SMF) actually possess weak and randomly distributed intrinsic birefringence. When light propagates in single-mode fiber, its fundamental mode comprises two orthogonally polarized degenerate modes (\text{HE}_{11}^x and \text{HE}_{11}^y).
When the patch cord is shaken, bent, or twisted, the fiber undergoes mechanical deformation and external stress. Via the photoelastic effect, stress disrupts the circular symmetry of the fiber core, inducing additional local linear or circular birefringence. This leads to dynamic changes in the phase retardation between the two orthogonal polarization components, causing the State of Polarization (SOP) of the optical wave at the fiber output to wander drastically on the Poincaré Sphere.
(2) PDL Converts “Polarization Jitter” into “Optical Intensity Jitter”
Fiber optic links or measurement instruments (such as spectrometers, optical power meter probes, optical attenuators within demodulators, circulators, beam splitters, and the receiving surface of detectors) are typically not ideal polarization-independent devices; they all exhibit a certain degree of Polarization-Dependent Loss (PDL).
The PDL of a device is defined as the ratio (in dB) of the maximum to minimum transmission of an optical wave across all possible polarization states:
\text{PDL} = 10 \log_{10} \left( \frac{T_{\max}}{T_{\min}} \right) = \text{IL}_{\max} - \text{IL}_{\min}
Where:
  • T_{\max} and T_{\min} are the maximum and minimum transmittances of the device for any input polarization state, respectively;
  • \text{IL}_{\max} and \text{IL}_{\min} are the maximum and minimum insertion losses, respectively.
When shaking the patch cord causes the polarization state to dynamically shift between the principal axes corresponding to T_{\max} and T_{\min}, the instantaneous transmission loss of the entire link fluctuates between \text{IL}_{\min} and \text{IL}_{\max}. The optical power received by the detector then exhibits slight jitter synchronized with the shaking frequency.
2. Secondary Influencing Factors: Micro-bending Loss and Mechanical Contact Perturbations
In addition to PDL effects, the following physical factors may also contribute additively under specific conditions:
  1. Bending Loss Fluctuations:
    If shaking causes a drastic reduction in the fiber’s bending radius (approaching or falling below its critical bending radius), the fundamental mode field distribution shifts towards the cladding, increasing radiation mode loss. Changes in curvature during shaking directly cause transient additional loss.
  2. Connector End-face Contact Micro-movement:
    If the fiber patch cord connector (e.g., FC/APC, LC) is not fully tightened or the ferrule housing has mechanical play, the lever stress generated by shaking the patch cord can cause micron-level lateral displacement or air gap modulation at the connector end-face, leading to Fresnel reflection and coupling loss fluctuations.
3. Engineering Suppression and Countermeasures
In precision optical metrology or fiber optic sensing engineering, if this jitter needs to be eliminated or reduced, the following approaches are typically employed:
  • Select Low PDL Devices: Ensure that the PDL specifications of optical attenuators, couplers, and detector probes in the link are better than 0.05\ \text{dB}, or even 0.01\ \text{dB}.
  • Utilize Polarization-Maintaining (PM) Optical Paths: Replace standard single-mode fibers with polarization-maintaining fibers (e.g., OFSCN® 300℃ Polyimide Panda-type PM Optical Fiber). Coupled with PM patch cords and polarization-aligned splicing, light is strictly confined to propagate along one principal polarization axis, preventing mechanical perturbations from causing polarization state crosstalk and wandering.
  • Introduce Depolarizers: Add a fiber depolarizer (e.g., Lyot depolarizer) after the broadband light source to reduce the degree of polarization (DOP) of the source, transforming it into quasi-unpolarized light, thereby desensitizing the PDL response of subsequent optical paths.
  • Structural Reinforcement and Rigid Patch Cords: Employ patch cords with stainless steel armored protective sheathing or rigidly fix the patch cords to suppress high-frequency micro-bending and mechanical jitter.
