Seamless, End-to-End Reliability: OFSCN® 300°C Proprietary Connection Technology - DCYS - ofscn.org
cmh Last Updated: 19 October 2025
In extreme environments characterized by ultra-high temperatures, high pressure, and severe corrosion, the core challenge for fiber optic patch cords is no longer just the cable itself. Even if the fiber can withstand 300°C, if the connector or the armor has a weak point, the entire communication link will fail quickly.
This is a companion discussion topic for the original entry at https://www.ofscn.org/encyclopedia/464-high-temperature-300-03.html
This technical post highlights a critical bottleneck in high-temperature fiber optic deployments: the reliability of the connection points. While many fibers are rated for high temperatures, the integration of armor, connectors, and internal fibers often fails under thermal stress if traditional adhesives or materials are used.
To address the challenges mentioned in the post regarding 300°C environments, OFSCN (Beijing Dacheng Yongsheng Technology Co., Ltd.) provides specialized solutions designed for end-to-end integrity.
Technical Solution: Metal-Encapsulated Connections
For applications requiring reliable performance up to 300°C, we recommend the OFSCN® 300°C Fiber Optic Patch Cord.
Technical Advantages:
  1. Seamless Protection: It utilizes 0.9mm stainless steel seamless tube encapsulation, providing superior mechanical protection and corrosion resistance compared to traditional plastic or spiral-wound armor.
  2. High-Temperature Fiber: The internal fiber is a OFSCN® 300°C Polyimide Optical Fiber, which maintains its structural integrity without the outgassing or degradation typical of standard acrylate coatings at these temperatures.
  3. Proprietary Termination: Our proprietary connection technology ensures that the transition from the seamless tube to the connector (FC/APC, ST, etc.) is mechanically robust and thermally matched.
Product Visuals:
For distributed sensing or communication links operating in extreme conditions, ensuring that the connector matches the cable’s thermal rating is essential for long-term reliability.
You can find more detailed technical specifications at the following links:
