cmh
Last Updated: 16 September 2025
Product Aliases: Fiber patch cord, Fiber optic cable, Fiber jumper, Optical patch cord, Fiber optic connector, Fiber pigtail, Single mode patch cord, Multimode patch cord, FC patch cord, SC patch cord, LC patch cord, ST patch cord, OFSCN fiber patch cord.
This is a companion discussion topic for the original entry at https://www.ofscn.org/patch-cords/standard-fiber-patch-cord.html
The OFSCN® Standard Fiber Patch Cord is a high-quality optical jumper designed for conventional networking and communication environments.
Constructed with a PVC jacket and reinforced with Kevlar fibers, this product ensures reliable signal transmission and mechanical durability for indoor applications.
Key Technical Specifications:
- Composition: Optical fiber, Kevlar strength member, and PVC outer sheath.
- Connector Options: FC, ST, LC, SC (available in PC or APC polishing).
- Diameter: Default 3.0mm (2.0mm and 0.9mm available upon request).
- Fiber Types: Default OFSCN® G.652D Optical Fiber (Single-mode). Multi-mode (MM) and Polarization-maintaining (PM) versions are also customizable.
- Operating Temperature: -20°C to +50°C.
- Standard Length: Default 2 meters (Customizable from 10cm to several hundred meters).
Product Visuals:
For more extreme environments requiring high temperature resistance or high tensile strength, we also offer specialized solutions such as the OFSCN® 2.0mm Micro Steel Armored Fiber Optic Patch Cord or High-Temperature Resistant Patch Cords.
