Under continuous high-temperature conditions (e.g.,500℃), does an annealing effect occur within the refractive index modulation of the Fiber Bragg Grating?
Yes, under continuous high-temperature conditions, such as 500℃, an annealing effect does occur within the refractive index modulation of a Fiber Bragg Grating (FBG).
Explanation:
The refractive index modulation that forms the FBG is typically induced by UV light exposure, which creates photo-induced changes in the fiber’s core. When the FBG is exposed to high temperatures for extended periods, these photo-induced changes can gradually “anneal out” or decay. This thermal annealing leads to a reduction in the grating’s strength (reflectivity) and, critically, causes a drift in the Bragg wavelength. This phenomenon is a significant factor limiting the long-term stability and reliability of standard FBGs in high-temperature environments.
DCYS Solutions for High-Temperature Applications:
To mitigate the annealing effect and ensure stable operation at elevated temperatures, OFSCN® offers specialized FBGs and sensors designed for high-temperature applications. These products often utilize advanced fabrication techniques, such as femtosecond laser inscription, and employ high-temperature resistant materials or coatings.
For applications up to 700℃, you may consider:
- OFSCN® Gold-Coated Fiber Bragg Gratings: These gratings use a gold coating, which significantly enhances their thermal stability.
For temperature sensing at 500℃ and beyond, we have dedicated sensors:
- OFSCN® 500°C Fiber Bragg Grating Temperature Sensor: Designed for continuous operation up to 500℃.
- OFSCN® 800°C Fiber Bragg Grating Temperature Sensor: Capable of operating up to 800℃.
These products are specifically engineered to maintain grating integrity and minimize wavelength drift in demanding thermal environments.
