Downward Compatibility of High-Temperature Fiber Bragg Grating (FBG) Temperature Sensors
Problem Description
The discussion revolves around the compatibility of higher-temperature Fiber Bragg Grating (FBG) temperature sensors for use in lower temperature environments. Specifically, the user inquires why there are various versions of temperature sensors and if higher-temperature models can be “downward compatible” to measure lower temperatures.
Technical Analysis
Fiber Bragg Grating (FBG) temperature sensors are designed with different encapsulation structures and fiber coatings to ensure stable operation across diverse temperature ranges and environmental conditions. The variety in sensors stems from the differing temperature resistance of these materials (e.g., polymers for ambient/low temperatures, stainless steel/alloys for medium/high temperatures, and special alloys or ceramics for ultra-high temperatures, often paired with polyimide-coated or pure silica core fibers).
While a high-temperature FBG sensor can theoretically function at lower temperatures, it is generally not the most efficient or optimal solution due to several factors:
  • Cost Implications: High-temperature sensors require more advanced materials and complex manufacturing processes, making them significantly more expensive than their lower-temperature counterparts. Using them in applications not requiring their full temperature range leads to unnecessary expenditure.
  • Performance Optimization: Each sensor is calibrated and optimized for its specific design temperature range. Operating a wide-range sensor at the fringes of its capability, such as using an ultra-high temperature sensor for very low temperatures, may result in reduced measurement accuracy, resolution, and long-term stability compared to a sensor specifically designed for that lower range.
  • Physical Constraints: High-temperature encapsulations are often more robust and may be larger or less flexible. This can be a disadvantage in applications with limited space or requiring sensor bending at lower temperatures.
  • System Design and Measurement Point Capacity: Different FBG temperature sensors, when integrated with an OFSCN® FBG interrogator, can support varying numbers of measurement points per fiber. For example, an OFSCN® 100°C sensor may support up to 20 measurement points, while an OFSCN® 300°C sensor might only support up to 10 points on a single fiber with a 40nm interrogator. Choosing a wider-range sensor unnecessarily could increase system complexity and overall cost by requiring more sensor cables and interrogator channels for the same number of desired measurement points.
  • Calibration Formula Accuracy: The temperature-wavelength calibration formula provided with each sensor is optimized to cover its entire design range. When a sensor designed for a very broad range (e.g., -200℃ to 300℃) is used to measure temperatures within a much narrower sub-range (e.g., room temperature to 85℃), the inherent fitting errors of its broad-range formula might lead to less accurate readings compared to a sensor specifically calibrated for that narrow sub-range.
Solution & Recommendation
It is highly recommended to select an FBG temperature sensor that closely matches the actual maximum operating temperature and environmental requirements of the application. This approach ensures the best balance of performance, accuracy, and cost-effectiveness.
OFSCN (Beijing Dacheng Yongsheng Technology Co., Ltd.) offers a diverse range of FBG temperature sensors tailored for various applications:
For specific application requirements, including anticipating future measurement range expansions, customers are encouraged to directly contact OFSCN’s engineering team at dcys@ofscn.com. The team can provide customized solutions that consider the actual highest temperature, desired extended temperature range, required number of measurement points, and unique installation environment demands, thereby ensuring optimal performance, cost-efficiency, and future scalability.
Recommended Product:
OFSCN® Fiber Bragg Grating Temperature Sensor Series (Fiber Bragg Grating/Fiber Optic Grating - FBG Sensor - FBG Demodulator/Interrogator - FBG Temperature, Strain, Stress, Custom Products - Model Parameters Picture Specifications - DCYS - ofscn.net)
(Original Thread: 更高温度的光纤光栅温度传感器测量时可以向下兼容吗 - #4 by ofscn_presale)
