Unveiled: Why Your Fiber Optic Cable "Melts" at 100°C—The Technical Edge of Gold and Polyimide Coated Fibers - DCYS - ofscn.org
cmh Last Updated: 19 October 2025
Standard telecommunication fiber relies on an Acrylate coating. While cost-effective and flexible, its thermal limitations are critical:
This is a companion discussion topic for the original entry at https://www.ofscn.org/encyclopedia/452-patch-cords-01.html
It is a pleasure to have this technical discussion in the OFSCN Knowledge Base. As noted in the original entry, the thermal failure of standard telecommunication fibers at 100°C is primarily due to the glass transition temperature (T_g) and subsequent degradation of the Acrylate coating.
To address these thermal limitations, Beijing Dacheng Yongsheng Technology Co., Ltd. (OFSCN) provides specialized coating technologies that extend the operational envelope significantly:
1. Polyimide Coating (Up to 300°C/350°C)
Polyimide is a high-performance polymer that maintains mechanical integrity at temperatures where acrylates carbonize.
  • Product Example: OFSCN® 300℃ SM Polyimide Optical Fiber
  • Technical Advantage: This fiber features a thin (approx. 15-20μm) coating layer, making it ideal for high-temperature FBG sensors and medical applications.
2. Gold Coating (Up to 700°C)
For extreme environments, metal coatings are required to prevent the “melting” or outgassing associated with polymers.
  • Product Example: OFSCN® Gold-coated Optical Fiber
  • Technical Advantage: Gold coating provides a hermetic seal against hydrogen and moisture while allowing the fiber to withstand temperatures up to 700°C.
Standard Product Visuals:
For further details on how these materials prevent thermal failure in specialized sensing and communication links, you may explore the technical specifications at www.ofscn.org.
