Vibration-Resistant Fiber Connectors
Why are threaded FC connectors more vibration-resistant than push-pull SC connectors?
FC connectors are generally more vibration-resistant than push-pull SC connectors due to their distinct mechanical designs.
The primary reason lies in the threaded coupling mechanism of FC connectors. This design incorporates a threaded nut that screws onto the adapter, providing a robust, continuous physical contact and a high, consistent mating force. This secure mechanical lock ensures that the ferrule alignment and contact are maintained even under significant vibration or shock, minimizing the risk of signal loss or degradation.
In contrast, SC connectors utilize a push-pull latching mechanism. While this design offers quick and easy connection/disconnection, the latch relies on spring force and a simpler locking tab. Under severe or prolonged vibration, this latch can be more susceptible to slight displacements or momentary disengagement compared to the rigid, threaded connection of an FC connector, potentially leading to intermittent signal interruptions.
For applications requiring high stability and reliability in vibration-prone environments, the FC connector’s threaded design provides superior performance.
You can find more information about our robust fiber optic sensing solutions that often utilize FC/APC connectors here:
OFSCN® Alloy Tube Packaged Fiber Bragg Grating Strain Sensor
Here is an example image of a sensor that can be equipped with an FC connector:
