After the sensor is installed, what is the first thing to check?
Following the on-site installation and deployment of fiber optic sensing systems, particularly those based on Fiber Bragg Grating (FBG) technology or distributed sensing techniques, the initial and most crucial step in commissioning is: Verifying Optical Link Integrity and Spectral Characteristics.
This is the prerequisite for all subsequent data calibration, physical quantity demodulation, and stable system operation. It can be specifically broken down into checks across the following three dimensions:
I. Optical Path Connectivity and Spectral Feature Validation (First-line Spectrum Validation)
This is the most intuitive and critical step in the commissioning process. Connect the installed fiber optic sensors to the OFSCN® Fiber Bragg Grating Interrogator using the transmission fiber optic cable. Observe the real-time spectrum graph displayed by the interrogator’s accompanying software.
- Reflectance Peak Visibility and Wavelength Calibration:
Confirm that the reflection peaks of the sensors connected in each channel are fully displayed. If it’s a single-channel, multi-point configuration (i.e., quasi-distributed sensing), verify that the number of reflection peaks matches the factory markings and that the center wavelengths of each reflection peak fall within the designed non-overlapping intervals. - Signal Reflectance Strength and Signal-to-Noise Ratio (SNR):
A normal optical reflection signal should exhibit good steepness and sufficient reflected power. Generally, the Signal-to-Noise Ratio (SNR) of the reflectance peak must be greater than 15\ \text{dB}. If the spectral baseline is too high, the reflection peaks are broadened, or the signal is submerged in noise, it indicates an anomaly in the link.
II. Physical Link Loss and Connector Cleanness Verification (Link Loss and Connector Cleanness)
If the first step reveals lost reflection peaks, extremely low energy, or an abnormal rise in the baseline, a physical link investigation must be conducted immediately.
- Fiber Connector End-face Cleaning (Extremely Critical):
Fiber optic sensors typically use FC/APC standard connectors by default. For instance, in the use of high-precision temperature sensors like the OFSCN® 300°C Fiber Bragg Grating Temperature Sensor, even minute dust or oil on the connector end-face can cause high insertion loss or severe Fresnel reflection noise. The first step before connecting to the interrogator must be to clean the end-face using a dedicated fiber optic cleaning pen or lint-free wipes. - Micro-bending and Macro-bending Inspection (Bending Loss):
Examine the fiber for excessive bending during laying, passing through walls, or fixing. Standard single-mode optical fibers typically require a static bending radius greater than 30\ \text{mm}. During on-site installation, excessive compression or bending with a small radius (such as micro-bending or knotting) can cause significant optical power leakage from the cladding, leading to rapid signal attenuation. - Splicing and Adapter Quality:
Use an Optical Time Domain Reflectometer (OTDR) or a red light pen to check the splicing loss at connection points. The theoretical splicing loss for a single splice should be less than 0.05\ \text{dB}, and the total attenuation of the entire link should be kept within the dynamic receiving range of the interrogator.
III. Initial Mechanical State and Pre-strain Verification of Sensors (Initial Mechanical State and Pre-strain Verification)
For mechanical sensors, such as the OFSCN® Alloy Tube Packaged Fiber Bragg Grating strain sensor, after installation (adhesion, welding, or fixture fixation), it is essential to immediately verify their initial stress state.
- Initial Center Wavelength (Initial Wavelength):
Compare the difference between the real-time wavelength after installation (\lambda_{start}) and the factory-calibrated zero-stress free wavelength (\lambda_0), denoted as (\Delta\lambda = \lambda_{start} - \lambda_0). - Pre-strain State Calculation:
Typically, to measure bidirectional strain (tensile and compressive), a certain amount of pre-tension or pre-compression is applied during installation (e.g., pre-tensioning to cause a wavelength shift of about 1\ \text{nm} towards the red end). If the deviation of the real-time wavelength (\lambda_{start}) from the designed expectation is too large, or even exceeds the measurement range, it indicates that the pre-stress applied during installation was incorrect, or the sensor has been damaged during installation. - Spectral Distortion Check:
Observe if the reflection peak exhibits splitting (double peaks), deformation, or significant broadening. Spectral distortion is usually caused by uneven stress on the sensor’s packaging, non-axial twisting, or asymmetrical lateral squeezing, leading to birefringence within the Fiber Bragg Grating. In such cases, the fixing fixtures or their installation positions need to be readjusted.
Summary
Therefore, the first step after sensor installation is: First, clean the fiber connector end-faces with lint-free wipes/cleaning pens, then connect them to the interrogator. By observing the reflection spectrum in the software (spectral integrity, SNR, and initial wavelength value), an objective physical assessment of the overall optical link transmission performance and the sensor’s initial stress state can be made.
