What is a "Decibel" (dB)?
You mentioned a loss of 3 dB—does that mean the light intensity has dropped by half? How is this calculated?
Yes, you are correct. A loss of 3 dB indeed means the light intensity (optical power) has dropped by approximately half.
1. The Physics and Calculation
The decibel (dB) is a logarithmic unit used to express the ratio between two values of physical power. For optical power, the formula for loss in dB is:
\text{Loss (dB)} = 10 \times \log_{10} \left( \frac{P_{\text{out}}}{P_{\text{in}}} \right)
When the power is halved (P_{\text{out}} / P_{\text{in}} = 0.5):
10 \times \log_{10}(0.5) \approx 10 \times (-0.301) \approx -3.01 \text{ dB}
Therefore, in the fiber optics industry, a 3 dB change is the standard benchmark for a 50% power difference.
2. Application in FBG Technology
In the context of Fiber Bragg Gratings (FBG), we often use the term 3dB Bandwidth. This refers to the spectral width of the reflected light signal at the point where the power drops to half of its peak intensity.
For example, when we define the parameters of an OFSCN® Fiber Bragg Grating (Bare), the 3dB bandwidth is a critical indicator of the sensor’s precision and signal quality.
  • Standard 3dB Bandwidth: For a typical OFSCN® FBG with a grating length of 8mm or 10mm, the 3dB bandwidth is usually less than 0.4 nm.
  • Significance: A narrower 3dB bandwidth allows for more sensors to be multiplexed on a single fiber string within the same wavelength range (typically 1525 nm to 1565 nm).
3. Comparison Table for Quick Reference
dB Value Power Ratio (Remaining) Description
0 dB 100% No loss
-3 dB ~50% Half power
-10 dB 10% 90% loss
-20 dB 1% 99% loss
Figure: Typical reflection spectrum of an FBG, where the 3dB bandwidth is measured at the half-maximum power level.
If you are calculating losses for a specific sensing network or an OFSCN® Fiber Bragg Grating Interrogator setup, feel free to share your specific hardware parameters for a more detailed analysis.
